Old 01-13-2022, 01:53 PM
dld's Avatar
dld dld is offline
Default 70 Power window wiring
I need some help with the p/w wiring. putting my 70 back together I cant find the power wire. (red)? . or where it plugs or gets power from
I cant find a wiring diagram for the harness
Old 01-13-2022, 03:59 PM
Formulabruce's Avatar
Orange / black. believe, and plugs into fuse box in the middle in "Ign" here is your diagram for 70 and 71
" Long may we DRIVE !"
Old 01-13-2022, 04:29 PM
dld's Avatar
dld dld is offline
Thank you much!
Old 01-13-2022, 04:34 PM
dld's Avatar
dld dld is offline
my 65 has a relay on engine side of firewall . I knew there wasn't a fuse but couldn't find any lose plugs . or a relay
I will check under dash for something unplugged. now I have a idea what to look for
Old 01-14-2022, 02:30 PM
murphc4 murphc4 is offline
This page has some pictures and info that might be useful to you.
http://www.firebirdtransamparts.com/...dows/power.htm
Old 01-14-2022, 06:01 PM
dld's Avatar
dld dld is offline
Yes ,
The pics really help. So the wire that plugs to the fuse panel powers the relay .
Thanks for that
This car has power locks also . so far they only unlock . I don't have seats in yet . So I'm thinking the seats work with locks . may need to install seats to search issue that out
Old 01-15-2022, 06:36 PM
The seats on some later models had a switch for the seat belt light, but nothing else.
If your locks only work one way then most likely it's either the contacts on the switch, or the solenoid itself is worn out.
I have a pair of solenoids and they work on the bench, but they aren't strong enough to lock the doors.
Old 01-15-2022, 07:22 PM
Locks are independent of seats. The PDL actuator is a 2 way Solenoid so reversing the Hot is what unlocks or locks the door.
Only one direction usually means a switch issue if its both doing same thing.
Newer cars use a stepper motor and a worm gear thats much lighter, more reliable and uses way less current.
Easy to upgrade and not seen.
Old 01-17-2022, 01:39 PM
dld's Avatar
dld dld is offline
my seats lock and un lock with a door jam contact . like the dome light does.
Formulabruce , i looked at the ones from Ames . If i don't get these to operate correctly . I will go in that direction .Do you have experience with there's.
the locks worked on the bench . But don't even make a noise in the car . I will switch the wires to see if its the switch . Are those switches available ?
thanks Don
Old 01-17-2022, 02:24 PM
thanks Don
I have never seen a 70 F body with door switches for the seat Locks, BUT I have seen provisions for it.
I run a MES system and use a remote to keep keys off the car.( door locks) This can be wired with the dash switch, or without.
Old 01-17-2022, 03:28 PM
johnta1 johnta1 is online now
Here's some pics from the 70 Firebird Supplement:
and the wire color code:
Old 01-17-2022, 03:40 PM
Seat Back Diagram:
Old 01-17-2022, 04:29 PM
dld's Avatar
dld dld is offline
The seat back locks are included in the P/L option . so says the car shipping record . see pic
ID:	582116   Click image for larger version
ID:	582117   Click image for larger version
Old 01-17-2022, 04:49 PM
cool info. I researched this on a few 70 model birds in the past that had switches and wiring, but no seats.
I do know this, the newer motor/worm gear door lock units work much better
and use less power and weigh much less than the heavy Solenoids.
Yours seats have the solenoids in them still?
Old 01-17-2022, 05:00 PM
dld's Avatar
dld dld is offline
yes and work!. actually everything worked. the locks were interment , like the switch was bad . car wasn't hateful when I got it from guy in Michigan. 20 hour ride straight up and back to Maryland
note the relay on floor for seat backs
ID:	582120   Click image for larger version
ID:	582121   Click image for larger version
