Old 05-13-2021, 06:17 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Default 1973 Ventura
Finally decided to sell the Ventura as it hasn't been on the street or at the track now in nearly 2 years.
Stroked 428 four bolt main block to 455 CID, KRE aluminum heads from Dave at SD, makes more power than you could ever use, but very mild at a glance. No expense spared in the engine, transmission and diff/suspension. Can be driven anywhere and will run nearly into the 10's in full street trim thru the mufflers by simply lowering the tires pressure to 18psi, don't even have to shut it off or cool it down.
Dead solid reliable and turn key mechanically other than needing a new set of DOT's.
Frame is rock solid, nothing more than a little surface rust in a few places. Hasn't seen water other than from washing it in over 30 years. Body could use a little work, interior is rough. Still looks good and runs even better.
Getting out of the car thing and moving on to other adventures.
$15,000 firm, no trades, serious inquiries only.
Can send pics or can be seen in Mount Vernon Ohio 43050.
https://www.youtube.com/watch?v=8U9iDTv3zj4
https://www.youtube.com/watch?v=6zVdoLR-VzM&t=21s
PM or call me at the shop:
740-397-2921
Old 05-13-2021, 06:59 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
WTH has Cliff been hacked?
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
Old 05-13-2021, 08:11 AM
Cliff R's Avatar
Retired in April so downsizing some. I'll keep the business till it sells or I completely retire. Right now I'm still open but mostly selling parts. The business is also for sale, have a few folks looking at it but not much more than that.......
Old 05-21-2021, 04:25 PM
se428bandit's Avatar
se428bandit se428bandit is offline
I wish i had the money, this would be a dream car for me to own.
Old 01-12-2022, 10:29 AM
Cliff R's Avatar
bump.
It's still here and needs a good home....
Old 01-12-2022, 12:50 PM
vertigto's Avatar
vertigto vertigto is offline
Cliff!! You're back!!
Today is a good day.
Old 01-26-2022, 07:24 PM
Nathaniel1234's Avatar
Nathaniel1234 Nathaniel1234 is offline
Default PM sent
PM sent
