Old 01-26-2022, 07:15 PM
tom s tom s is offline
Got a email that said I should have a intake ready to pickup friday(???) but im not going to drive 50 miles each way on out freeways on a friday.Maybe Monday!
Guys that order a intake should start to think about a thermostat housing!They take the tripower-2-4 intake style.63 and 64s are similar but the direction are diff from each on direction.65-66 are kind of similar going toward the center.Trpower.com might have pics of all 4.Bart might have posted them on this site also.Tom
  #462
Old 01-26-2022, 07:49 PM
ANDYA ANDYA is offline
Great news Tom. Looking forward to seeing what the intake is going to look like. So far the top looks fantastic. You guys are doing a great job!
  #463
Old 01-26-2022, 07:51 PM
Also make sure your timing covers have the dimple for the forward facing thermo housing!Tom
  #464
Old 01-27-2022, 08:32 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
https://www.ebay.com/itm/33082602911...AAAOSwtJZXVhcV
Bought this thermostat housing last week. It came in two days. Chinese knock off butt I didn’t want to spend $600 on a factory one even though I probably tossed out a dozen of those
  #465
Old 01-27-2022, 08:22 PM
mgarblik mgarblik is offline
Thanks for the heads up. I just looked today at the cover I put on the engine I am building for the bathtub intake. It has that little dimple in the cover but is an 11 bolt water pump timing cover. What year did they do away with the dimple? I have no idea what year this cover is from.
  #466
Old 01-27-2022, 08:29 PM
Right around 1975 the dimples were eliminated.
I had a ‘74 cover with the dimple.
  #467
Old 01-27-2022, 08:41 PM
Thank you for the quick reply. I poked around on the Pontiac parts sites, Ames, Kauffman and Butler and NONE of the new 11 bolt covers they sell have the dimple provision. So it looks like old stock or nice used covers for tri=power or the 2x4's. I guess I just lucked out.
  #468
Old 01-27-2022, 08:56 PM
They have brand new 8 bolt style!Tom
http://www.krepower.com/Pontiac%20Timing%20Covers.htm
  #469
Old 01-27-2022, 09:45 PM
Thanks Tom. I did see that and they have the dimple of course. That would be a good option for some of the bathtub intake users getting the newer pattern intake as well.
  #470
Old 01-27-2022, 11:56 PM
wbnapier wbnapier is offline
On the Kaufman timing cover, I purchased the 8 bolt with dimple. There were some small issues.
It was not drilled for the location dowels, and that leaves some tiny adjustment that needs to be played with to center the crank seal properly prior to torquing. My machinist complained about this and I think he is right.
The inside of the water pump area is different from stock, which meant the divider plates wouldn't seat nicely without removing some material from the timing cover water bowl area and monkeying with the plates. Compared to stock, it was a hassle.
One, and maybe and another of the lower studs leaked coolant. For sure one pierced the lower radiator hose inlet casting. I don't know if stock is the same, but I didn't use thread sealant and it leaked and pissed me off.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
  #471
Old 01-28-2022, 11:04 AM
No big deal on the timing covers guys. There are still plenty of original GM covers to be had. From local swap meets to Norwalk to EBay they’re out there.
  #472
Old 01-31-2022, 06:28 PM
Well,another delay!Covid issue,say it will be a day or two?Killing me!Tom
  #473
Old 01-31-2022, 10:19 PM
sdbob sdbob is offline
Thank you Tom and others for all your time and hard work to make this happen.
The Following User Says Thank You to sdbob For This Useful Post:
  #474
Old 02-04-2022, 10:55 AM
We have a casting to machine!Will pick it up Monday and get it to John to machine!Tom
The Following 5 Users Say Thank You to tom s For This Useful Post:
  #475
Old 02-04-2022, 10:58 AM
JSuchma JSuchma is offline
AWSOME!!! Thanks Tom
  #476
Old 02-04-2022, 11:37 AM
here is my solution to that problem
https://forums.maxperformanceinc.com...ight=tri-power
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
  #477
Old 02-07-2022, 08:40 PM
Picked up a sample today of a early style for machining.John will start on it this weekend.
ID:	583721   Click image for larger version
ID:	583722   Click image for larger version
The Following 3 Users Say Thank You to tom s For This Useful Post:
  #478
Old 02-07-2022, 08:41 PM
What a work of automotive art!
  #479
Old 02-07-2022, 08:59 PM
Little work on the inside needs to be done by Lynwood.A little issue pulling the mold?Trying to get the best quality we can.Tom
  #480
Old 02-07-2022, 09:34 PM
beemergary's Avatar
Taking allittle longer will be worth it. Thanks Tom.
