389, TH400, AC, 4W Disc, 1800 miles on car since I completed chassis off rebuild. Full restroation picture documentation upon request. Must see. Beautiful Pontiac Widetrac !!! Motivated to sell, will negotiate.
Please inquire if interested.Thanks, TODD 42K Oldbluehusky@yahoo.com |
Did I mention complete frame off ? Fully powder coated chassis, suspension, core support, wheel houses, and interior trim bits. Have a look !!!
Please include your location, per board rules.
Morning Stuart,
Northern Nevada South of Reno. |
Small parts list
Original 389 CID Bore .030/Hone/deck block/align Grind crank .010 Clevite MS483G Scat balancer D-80020 Resize rods Clevite CB758P Pistons & align KB370 +.030/Sealed Power E253K Melling oil pump 10540 Cam bearings Durabond P4 Comp cam 51-2223-4 Comp cam 7112 Timing Set Comp Rockers 1251-16 Comp cam lifters 852-16 Comp cams 988-16 springs ReCon OEM heads bronze guides/SI Stainless valves/Viton metal clad seals/Bowl port/Gasket match surface Edelbrock 7156 RPM Performer Holley 0-8677BK Ultra Street Avenger 770 CFM Tuned Dougs Headers D-521-R MSD 8563 Distributor MSD 6425 6AL Digital Box MSD 31193 Wires MSD 8203 Coil ARP 190-3602 Head ARP 190-6001 Con Rod ARP 194-5401 Main Stud ARP 594-9801 Engine ARP 200-2904 Flex Plate Northern Aluminum Radiator/Duel Spal 3500 CFM Fans Original TH-400 All new: KB3400D Mok w/Borg 400/65-up 34903 Bushing kit 400/65-up 34402A Roller lower 400/4180E 34418X Sprag intermediate 400/4I 34325 Band front 400/425/4180E 400-1-2 Performance kit 400/65-up 38820 Modular red str small g 5A-100Solinoid valve body 400/6 K349007B Bearing kit torr 400/4180 34661 Filter 400 (e) 64-67 34501A Washer output 4 tang 400 34401 Washer center support dru GM3HD Torque converter Trans mount Flow-Master 817412 Stainless Exhaust Ames PR207D Front disc conversion/Rear Scar-bird Mounts NAPA 4885776 Hats/SE4689-90 Calipers CPP 6474BB-7 Master/Booster AND THE LIST GOES ON… .Want more info ?? OLDBLUEHUSKY@YAHOO.COM or shoot a PM for Phone number. Thanks, TODD |
