Test & Tune Ask questions about the features and functions of the Forums.
Old 01-29-2022, 11:01 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default Looking for a geek....
Not related to this site.....but want to save photos....from a Mecum auction .....and there is basically nothing....when I right click...
Any input is appreciated..
Old 01-30-2022, 01:40 AM
dataway's Avatar
dataway dataway is offline
The ability to right click download from a website is controlled by the code of the webpage, they can disallow it if they want to. Probably done on the Mecum site to prevent scammers from using the photos to sell imaginary cars.
There is always the option of expanding the image to "full screen" then hitting Shift and PryScn keys on your keyboard ... this saves a screen shot image to the clipboard ... should be able to paste it into a image/photo program and crop it down to just the photo.
Old 01-30-2022, 01:58 AM
Great info.......Thanks for sharing....
Old 01-30-2022, 11:58 AM
Shiny Shiny is offline
You can also use a "snipping" program to capture the photo on your screen. If you have a Windows PC, "Snip & Sketch" works well. Download it from the Windows Store if not already installed. Keep the icon in the tray at the bottom and it's a quick way to snag the image. You launch the program, then drag the capture window around the image, and save it or paste it. This saves having to paste the screen capture into another program to crop the image. It also lets you add lines or circles to highlight stuff.
Name:	Screenshot 2022-01-30 084754.jpg
ID:	583197   Click image for larger version
Name:	Snip & Sketch.jpg
Old 01-30-2022, 12:28 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Bring pictures up on your phone browser. Push power on and volume up to snap the screen picture to your phone ( assuming I phone).
Now images are yours.
Good luck
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 01-30-2022, 04:34 PM
Again more great info....Thanks
The wife will be an expert at this by tonite..
Old 01-30-2022, 06:09 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
As dataway said and you can download "irfranview" for free to modify resolution, size, and crop. More options also, good free software.
Old 02-10-2022, 02:32 PM
Ok...Thanks for all the input.....Mission accomplished
'nother question......I heard you can get a thumb drive.....that will copy/save only one file of each..
My picture files are a big mess right now...loaded with crap and duplicates.....and I have no idea where it all came from..
Current file content is about 100 gb....which is a bit less than 1/2 capacity.
Not looking for anything fancy....Just best bang...for the buck..
