Old 01-31-2022, 03:56 PM
AZDragracer's Avatar
AZDragracer AZDragracer is offline
Default My little 301 racer
Hope this is where I should put this post.
Here is my little Pontiac 301T racer.
301T .030 over
stock lift cam with a little more duration
stock unported heads
stock intake
stock exhaust manifolds
rejetted Qjet
Balanced but otherwise stock turbo
TH350 w/boss hog converter
8.5 rear with 4.10 gears and 30 inch tires (do the math for the final ratio)
cal-tracs
full interior, still has power windows
3850 lbs. with me in it (per class rules)
currently has 451 passes on on the longblock as of this weekend.
ID:	583265   Click image for larger version
ID:	583266   Click image for larger version
Rick Unterseh
Pontiac powered Dragster
80 Turbo Formula NHRA stock eliminator
Outlaw Pontiac Racers West
The Following 2 Users Say Thank You to AZDragracer For This Useful Post:
Old 01-31-2022, 04:31 PM
Skip Fix Skip Fix is online now
Cool! I have the 301T that was in the 81 car before I put the 400 in it. I was half apart form the previous owner. Has head studs and a supposed Ultradyne cam and had a Holley 3310 on it.
Old 01-31-2022, 08:05 PM
loaded down with 3850 Lbs, wow.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 01-31-2022, 08:28 PM
PunchT37's Avatar
PunchT37 PunchT37 is online now
Damn. 1`st 350`s and now 301`s.
The Following 2 Users Say Thank You to PunchT37 For This Useful Post:
Old 01-31-2022, 08:48 PM
Scott Stoneburg's Avatar
Nice! Very impressive from the mild combo
Old 01-31-2022, 08:56 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Very impressive!
