Old 02-09-2022, 04:04 AM
chuckies76ta's Avatar
Hi John: The measurements center to center on the bolt holes are 3". Hammertime Mike appears to be looking for one of these also. Post #24. I would also take one if you don't mind. Thanks. If it doesn't work out let me know. Keep me posted.
950 Quickfuel.
  #42
Old 02-09-2022, 12:07 PM
R 70 Judge's Avatar
Thanks Chuckie!
Can anyone confirm the 3.0" measurement? I want be 100% sure it is correct before having them made.
I looked up some of the SBC stuff and it all varied from 3.0", 3.20", 3.22", and 3.25"
James
1970 Trans Am
  #43
Old 02-09-2022, 12:35 PM
John. You can take the measurement to the bank. lol I measured the adapter and the crossover with two bolts in it. But your like me confirmation.
950 Quickfuel.
The Following User Says Thank You to chuckies76ta For This Useful Post:
  #44
Old 02-11-2022, 12:46 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Thanks for the post ! Yes, I'd be interested in this too. If Meziere is willing to make more than one. I'd be interested in two. Would gladly send money up front if this can happen. thanks Mike
Old 02-11-2022, 01:18 PM
Ya I can send money also up front. Whatever works for you. Thanks
950 Quickfuel.
  #46
Old 02-11-2022, 04:42 PM
R 70 Judge's Avatar
Okay I heard back. Unfortunately since it’s a custom part it’s going to be more expensive. Here’s part of the email. I ordered a mezeire billet flexplate so I left that part out.
“ If you want quick delivery I can grab some black parts from stock and modify. If you want to wait we can machine raw parts and send them for anodize so that the newly machined area is also black.
For four modified parts it will be $89 per.
However, if we don't have all four on-board we will need to readjust price.”
I am going to order two regardless. I plan on waiting for the new raw machined parts
If you guys are still in at the higher price ($89) let me know. If you’re out that’s okay. If anyone else wants in let me know ASAP.
James
1970 Trans Am
  #47
Old 02-11-2022, 04:47 PM
R 70 Judge's Avatar
Crap I just noticed we need our hose/fitting exits on either side of the bolt and not two exits on one side like the chebby stuff. I’ll have to ask about this.
James
1970 Trans Am
  #48
Old 02-11-2022, 07:42 PM
I'm still in. If we're lucky Meziere has some raw castings without the threaded holes in them yet. Thanks for the effort !!
Old 02-11-2022, 09:01 PM
misterp266's Avatar
What is gained by using the spacer as opposed to plumbing directly into the crossover? Seems like you’re making it more complicated than it needs to be.
" Darksiders Rule "
  #50
Old 02-11-2022, 10:10 PM
Hi James: I'll just pass. Probably won't use it anyway as I still have this one here. Thank again.
I posted #35 a pic of the one I have. If you need any measurements of the ports let me know.
950 Quickfuel.
  #51
Old 02-11-2022, 10:18 PM
The spacer is just a way to add water lines into the crossover. The two threaded ports that are installed by the factory are usually used for accessories, so there is no where for two more, hence the adapter. I had my Son weld two -10 fittings on the crossover. post #35 has the pics.
I used the two factory threaded ports, one for a temperature gauge in car and the other one for a sensor for my electric fans.
950 Quickfuel.
  #52
Old 02-14-2022, 01:27 PM
misterp266's Avatar
I added two fittings to the bottom of the crossover. Will be adding another one between the thermostat housing and the coolant temp fitting to hook up a bypass hose that will run down to the remote pump inlet side.
" Darksiders Rule "
  #53
Old 02-14-2022, 04:11 PM
Some nice plumbing there misterp266
  #54
Old 02-15-2022, 03:58 PM
R 70 Judge's Avatar
We should have the final answer today. I’m asking for 4 to be made (two for you and the other two for me). I’m making sure we can have the threaded machined fitting holes in the correct spot for our pontiacs.
James
1970 Trans Am
  #55
Old 02-16-2022, 07:18 PM
Sounds good , thanks for the heads up !!
Old 02-22-2022, 02:49 PM
R 70 Judge's Avatar
Update: Unfortunately Meziere said they could not change the outlet locations to either side like a Pontiac requires, as they are pre-machined for them. I told him I'm going to pass on having the 4 parts made at this time.
I'll just wait until Precision Automotive Specialists gets them back in stock... or I'll just say screw it and weld fittings into my crossover
http://www.precisionautomotivespecia...Manifolds.html
James
1970 Trans Am
  #57
Old 02-22-2022, 06:29 PM
punkin punkin is offline
Looks great. Did you simply drill and tap for the elbow connectors or did you epoxy as well?
I've been on the waiting list with precision for some time now. The owner and I had some dialog way back where he was doing some design work for a unit that is better suited for street and can be used with a thermostat...this is what I understood from our conversation.
1968 Firebird
IA2 522
340 E-heads
Northwind 950 Carb
4L80E
3.50:1 Rear
1969 Firebird
IA2 535
Northwind (Induction undetermined)
3.50:1 Rear
  #58
Old 02-23-2022, 07:02 PM
Thanks for trying !
Old 02-23-2022, 07:30 PM
misterp266's Avatar
Holes are drilled and tapped. Elbows needed to be “clocked” so tapping was stopped at the point of proper orientation when tightened. No epoxy.
You could always drill and tap another hole in a Meziere spacer on the opposite side and plug the one not used. Just a thought.
To me, one of the most enjoyable parts of building something non stock is figuring out things and making them work. It also makes it “yours” and sets you apart from the masses.
Here’s a couple of pics from my first non stock cooling system. I designed and built it in the late ‘80s. Pics aren’t that old though. Modified Weiand front cover, hand made adapters to use a SBC electric water pump on top of a home made front motor plate. The Algon injection is just sitting there, I never ran it. Not in the pics is a custom billet thermostat housing with radiator cap because the radiator was lower. It all worked great.
ID:	584770   Click image for larger version
" Darksiders Rule "
  #60
Old 03-09-2022, 04:47 PM
Don 79 TA Don 79 TA is offline
Ya, I left my water bypass in use so the water does move into timing cover to pump. I have the thermostat removed as of now and well see how it works when weather changes here.
Right now I have plumbed back of heads to water crossover. I already have somewhat of a restrictor in place. I have an adapter plate on the crossover that divide the front and back water flow.
Adapter http://www.precisionautomotivespecia...Manifolds.html
when routing the water from the back of the cylinder heads to the water neck spacer, does that give a good reduction in temps? what have others seen?
Would i see a benefit doing that over routing the two back passages on the head to the heater nipple on the timing cover?
I have the rear passages blocked off now and the heater nipple is also blocked off
If something sort of simple like either option aids in additional cooling i'd like to try it. I have a road where i have to run 3rd gear at 30-35 and thats when my temps climb, especially past 95 degree outdoor temps
also what size adaptor would i need for the rear round port e-heads to say a #8 line would i need? I have plenty of #8 and #10 hose around, i'd just need a few fittings. figured since i planned on flushing the cooling system, this would the perfect time to make this type of change.
i run the electric water pump and 160 stat now with a good 1.25" dual core aluminum radiator and the summer night temps can still be well over 100 degrees outside.
