Closed Thread
Old 02-21-2022, 06:37 PM
tom s tom s is online now
Sorry guys,if someone can straighten it would be great.There could be a mm diff one way or other but going to be pretty accurate.Anyone using or trying to use Holleys will have to add the thickness of the adapters and spacers if run.EVERYONE SHOULD be aware of exactly what I went through to get large top AFBs under the hood on a 62 GP with out cutting the hood.Tom
Old 02-21-2022, 06:54 PM
Skip Fix Skip Fix is online now
Thanks Tom!
Old 02-22-2022, 05:40 PM
misterp266's Avatar
misterp266 misterp266 is online now
Turned.
Just got a nice 538568 ‘63 Tri Power aluminum water neck.
ID:	584708   Click image for larger version
ID:	584709   Click image for larger version
" Darksiders Rule "
Old 02-22-2022, 07:35 PM
Thank you,a little more EZ to read.Tom
Old 02-22-2022, 08:33 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
A bit easier to see, ok on the laptop, looked small on the phone unless I downloaded them, text you tomorrow Tom.
Much Thanks!
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 02-23-2022, 12:31 PM
Charlie Jones Charlie Jones is offline
Oh goody!
Now there will be more 421 Super Duty's exant than were ever made in the first place.
Save your empty beer cans, The Japanese need 'em to make cars!
Old 02-23-2022, 12:45 PM
There already is.There were 2 batches of Bathtub intake made over the years.I would say about 50-60 already.Also the repops are better than the factorys!Tom
Old 02-23-2022, 01:19 PM
61-63 61-63 is offline
Not to mention all of the 54299/91, 9770319, and 9770859 intakes that were sold over the counter and which are now on who knows how many tribute cars? Not bathtubs but certainly 421SDs.
Old 02-23-2022, 01:34 PM
4zpeed's Avatar
Originally Posted by Charlie Jones View Post
Oh goody!
Not interested in a tribute, just wanna soak in the Tub and bask in the sunlight...
Frank
Old 02-23-2022, 09:45 PM
JSuchma JSuchma is online now
Oh goody!
Impossible........no one is producing heads yet!
Old 02-24-2022, 11:21 AM
beemergary's Avatar
Run the 859's on both my 421sd's. But my ultimate goal is to have a bathtub and almost there. The pontiac God's are looking down. Thanks guy's
Old 02-25-2022, 05:59 AM
Originally Posted by JSchmitz View Post
"421 SD repo intake project" Repo? Didn't you pay for it? LOL How about repro? Just kidding!
Looks great! I keep trying to find a way to justify buying one.
Mikes Reply: "Try to find a reason "NOT" to buy one".
(1) Mike, would like to know "How many Ponies will I get over my current HP level?
(2) Is It required to Port match my "D"- Port Heads to the Bath Tube Manifold from the start?
(3) Here is a better description of my existing set up: Since I have a 1979 TA Scoop, open toward the Windshield, over the existing Tri-Powers on top of my 1976 Formula Hood and the "Poor designer" before me, "did not" account for the forward most Carb. height (the Scoop should have been installed more forward to fit correctly) I use a small Filter on top of the forward Carb. The Center and Rear Carb. clear well. That being said, I run a 1979 Pontiac TA with the 428 HO. "Will I have any issues fitting the Air Filters, if I go with the 409 carbs"? What is the 409 Carb? "Is it an exclusive type, just for the Chevy 409"? Do I have a second practical choice to Carburation?
Old 02-25-2022, 06:23 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
LOL! True!
I have a long list of reason not to. Like I have a big pile of parts to buy to get my car back together.
Old 02-25-2022, 03:43 PM
LOL! True!
I have a long list of reasons not to. Like I have a big pile of parts to buy to get my car back together.
Mikes Reply:
Don't feel bad, I have to rebuild the TH400 on my Vehicle and I am reading all my saved files in order to accomplish this task. My roommate is doing the same thing. Soon we will watch some Videos and build our confidence up. I have the parts to rebuild it, but I am sure we will find some hard parts inside to replace. This is first in my priorities and foremost.
Old 02-26-2022, 12:18 AM
3783 AFBs are another good choice for carbs.Tom
Old 02-26-2022, 09:19 AM
Mikes reply: To Charlie Jones!
Extinct, I think you mean?
Old 02-26-2022, 09:48 AM
Mikes Reply: If you are saying "It is Impossible to buy any Trans. kit parts meaning: Seals, Bushings, Steels and Clutches you are semi-correct. However, I was turned down by two companies that sold the rebuild Trans. kits, so I jumped on the third one, that happened to be, an in-stock "B+M" kit, without the Kolene Steels nor the Torrington Bearings. I can live with the Regular Steels and I bought the Torrington Bearings else ware. I bought the extra special rear Case Bushing with Shims & Bearing, only to find that Sonnex carried a better version with a Lip to keep the Bushing from moving out toward the rear of the case. I had to purchase the Thrust washers kit else ware too and then I ordered an extra Shim kit for End-Play Tolerances, since I am" not" stocked, as a Transmission shop would be. Presently, I am learning all I can before I open the Case, the Trans. is in my shed awaiting dissection. I just hope I can get any hard parts online when it is time.
Mike here: now that I re-read your Post, the meaning went of it went over my head, with these one liners people throughout, in a split second, my bad.
  #38
Old 02-26-2022, 10:52 AM
How the hell did we end up on transmission parts on a thread about a bathtub intake?
Never mind…
Thank you Tom for your efforts on this!
Keep on topic guys or just start another thread already…
The Following User Says Thank You to Sun Tuned For This Useful Post:
  #39
Old 02-26-2022, 11:37 AM
S.T. I have you early on the list for a late style intake!You still want one?Sent you a PM awhile back.Your number 6 on the late list.Tom
  #40
Old 02-26-2022, 12:12 PM
You betcha I do!!
Closed Thread
