Old 03-05-2022, 08:21 AM
mysticmissle's Avatar
Troy, shame on me for engaging a post of yours.
the Hiports i had bought, ready to run, are using a little water, but they still faster @ 3650#s than you will ever be. #=pounds in case you did not know.
good luck with your E heads and blem block combination. The amount of money you are spending to not build your aftermarket combo is awesome.
Thanks for checking in.
Lets not turn into Tom and George OK? Good
The Following User Says Thank You to mysticmissle For This Useful Post:
  #42
Old 03-05-2022, 09:06 AM
slowbird's Avatar
slowbird slowbird is offline
Troy is also building that stock block HP headed pump gas engine that's going to set the horsepower record for stock block on pump gas (whatever that is), so he does have a lot going on.
  #43
Old 03-05-2022, 10:59 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Originally Posted by Dragncar View Post
Yeah Paul.
I made the post and was on my way to work 5 minutes later when I realized my brain fart. Nothing I could do about it, could not delete it, edit it in time.
I know how it looks. In a hurry, people asking me questions, lot on my mind.
Life goes on. Lot bigger thing going on in my life at the moment, good things.
I wanted to answer RA462 quickly because he is cool, try it sometime.
I have 4 sets of roller rockers and 2 sets of shafts and most of them say what they are right on top.
For some reason I was thinking the Jessle lifters had their offset stamped on them thats why I opened up the box. Glad I did, wanted to check them for rust. They are all good, had a NIB set rust on me before.
Good to know glad I could help out. That's what these forums are for.
Go fast, see Elvis!
  #44
Old 03-05-2022, 11:03 AM
PAUL K's Avatar
I thought he already did that with his last engine?
I remember him posting his HO heads were the fastest ones out there?
I know they were quick, as they went only two tenths slower than mine. But I was four hundred pounds heavier, had an tight street converter, less gear, full exhaust, street tires, and didn't race at sea level.
Go fast, see Elvis!
  #45
Old 08-06-2024, 11:58 PM
R 70 Judge's Avatar
Here is the Crower Endura shaft rockers with optional offset.
https://www.jegs.com/i/Crower/258/74165/10002/-1
Promo code gets them down to 1540 $
Did you end up buying these? If so, how did they work out? I’m considering these for my future parts pile for when I freshen things up.
James
1970 Trans Am
  #46
Old 08-07-2024, 12:24 AM
Dragncar Dragncar is offline
I did get them. Very nice, pretty easy to set everything up. Just take your time, check and re check.
They look like jewelry under the hood.
How much are they now ? I got mine for 1540 $
The engine is up and running. Made a few test passes. No leaks, sounds sweet.
Have not tried to tune it yet, maybe later this month.
Only hooked the car once, had a 1.41 60 foot which is better than the car ever did with the old engine. But only had 28 deg timing. Did not MPH so I have some work to do finding it what it likes. No dyno and testing at a track takes forever, hard to get runs in.
I would think there is a 1.37-1.38 in the car and that would get me where I want to be.
Not going to thrash on this engine anyway. Hope to put the HOs back on it and the High Ports on the 540. I can thrash on it all day.
