I bought a kit to move it back to the shifter in the console for my '69 only because I've changed the transmission to a 200-4R. The original back linkage still locks the steering wheel but I don't have to worry about if the P/N switch still would have worked since the detents for the gears aren't the same as the Turbo 400.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD '83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO 2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO '55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO |
| The Following User Says Thank You to roger1 For This Useful Post: | ||
Opinionated? I resemble that even if not electrical... Opinions are for everyone. Soldering is good and makes electrons happy. You are wise. Mike |
| The Following User Says Thank You to Shiny For This Useful Post: | ||
My next car I might wire the whole thing with Wago Lever Nuts, you could reconfigure the whole schematic without any tools
I love those things.A few days ago I temporarily moved the electronics bench upstairs out of the shop, which might become permanent. I don't find the 55 degree shop conducive to quality wiring work so I do what I can up here and then take it down to the shop. BTW .. the soda can has water in it for the soldering station, I don't drink soda.
| The Following User Says Thank You to dataway For This Useful Post: | ||
I have found this works mighty fine:
| The Following User Says Thank You to Kenth For This Useful Post: | ||
Kenth, so that setup only requires the positive cable to the starter?
That was the popular thing to do back in the day using a Ford solenoid and the approach that I referred to in my prior post. You show a good diagram on how it was hooked up.
It's not necessary if using a mini starter nor will it even work wired that way. On a mini starter you can't use a jumper and must run the purple wire to the solenoid on the starter. I think it's always better not to run the car's main power source wire down to the starter solenoid. Plus, I think it's much better to use a high amperage fuse holder and fuse (the screw-down type) instead of fusible link. Again, I am just completing all this wiring on my car now and will be posting photos soon in my build thread.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD '83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO 2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO '55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO Last edited by roger1; 03-08-2022 at 10:01 AM. |
I worked as a Pontiac tech from '73 through 1985. Popular electrical problems were alternators, starters, back up light sockets in the bumper, 68 GTO tail light sockets, wiper motors, window leaks, trunk leaks, squeeks and rattles, carb rebuilds, tune ups, shhocks, exhaust, power steering leaks. 12 month, 12k mile warranties. Tons of warranty electrical problems. Most cars coming in had less than 50k miles, never saw 100k.
Quite different from todays cars.
I'm just curious but do you know how the repair data was shared with Pontiac/GM? Did you ever see a list of "frequent" or "top" repair actions, either under warranty or not? Clearly they had what I call a "quality management system" and I'm curious to know how it worked. I've never seen discussion of this on the forum.. but I've never gone looking for it either ![]() For example, I'm sure you got repair bulletins and parts change notices that were based on dealer service data (although some changes were probably trigggered by discovery in factory or engineering tests - "late discovery"). The top of the list may also have guided staffing decisions for your management (ie how many hours for a typical repair to decide how many techs were needed). And as long as I'm spewing random questions, did service department managers report to the dealership or did they have their own management chain within Pontiac/GM? |
All the mini-starters I have used is wired like that? I use a short piece of wire with appropriate fitting on each end and fasten it to the solenoid and to starter post.
If I were to mount a battery in the trunk, then I would use a remote solenoid next to the battery whether I was using a mini starter or not. It's a good for safety when the positive cable is that long to have it only be hot when the engine is cranking.
Also, the positive cable to the starter is hot only at "start". |
I can remember '78 Firebird GM T-top roofs collapsing behind the windshield over railroad tracks. Those claims and the following caught the attention of PMD. Roofs on '78 G bodies rotting out, Transmission coolers on early 70's cars failing. When gasoline started having alcohol added, around 1979, it destroyed accelerator pumps causing a change to Viton. Early speedo hall-effect sensors failed regularly. Serious warranty findings from the dealer level would generate a Service Bulletin. No list of common repairs, you just remembered it. A walk through the parts room could tell you the popular repairs. Quality at the dealer level was important, but a short step behind making money. All warranty parts had to be saved for 90 days when a GM rep would approve them for scrap. Some parts PMD was interested in inspecting due to increased warranty claims. Staffing was determined by work load/reasonable repair time, shop space was also a consideration. There were flat rate books and GM had their own warranty times. Service managers reported to the dealer owner or general manager. Larger dealers usually had a manager that oversaw Service/Parts/Body Shop. The individual managers reported to that manager. Around 1979, Michigan required that mechanics be ASE certified which was not welcomed with open arms back then. Then in 1980 cars had the first computer and much training was required. People didn't have home computers yet, nobody knew how to fix these things. Pretty rocky time for a mechanic, a lot to take in.
HoovDaddy - Thank you for taking the time to share all this. It's interesting for me and you know a lot.
Please forgive the rambling below and sorry to OP and others for the diversion but it's the way I am. Quote:
Thanks again for sharing your experience. Mike |
Please continue, I'm loving the information.
This forum is a way for me personally to learn from others. I hope that doesn't end. Thanks to all for sharing your experience.
Circling back to your original post after following all the replies, yours is the only mention of evidence of "too much heat" in that purple wire. Was it the wire or the connectors? It was interesting to learn there was no "fast" fuse protecting that wire, but instead a fusible link. I interpret this fusible link as a "slow-acting" fuse. Is this correct? I hope so, because any wire not protected by a fuse seems a fire hazard and would surprise me. This is an interesting design decision itself! There are comments regarding starter functional failure from heat soak and great info on "why" that happens and how to avoid it.. but the "root cause" was more about a susceptible starter/solenoid design and not about lack of a relay feeding the starter relay (solenoid). You questioned the original design decision to eliminate a relay between starter switch and solenoid, right? So.... Maybe HoovDaddy or others with similar experience can comment on how often they had to replace the purple wire, the fusible link, or anything in that circuit because of "heat" damage? Did that purple wire ever start fires? HoovDaddy's comments suggest the decision decisions were heavily focused on getting past a 12-month/12,000 mile warranty in 1968. Given the lack of a service bulletin to add a relay suggests GM/PMD saved more money eliminating the relay than it cost them in warranty repairs. Was it a good decision? I dunno, but the answer is probably different for you now than for PMD in 1968. When did this starting system design first appear? When did the design change to eliminate mechanically switching the high current to the solenoid? The "longevity" of this design approach could hint at how it worked out (at least for GM/PMD). How it worked out for you is now known! Mike |
The purple wire on my car only shows signs of heat at the connection points.
I think Roger mentioned that there WAS a service bulletin concerning that wire, not sure if it included a relay .. probably not as it was not seen on the 69. I guess we would have to define "longevity" since I seriously doubt GM gave a crap about what happened to cars 10 years after they built them. Probably the only upside to EPA regs on modern cars is that they require so many parts that are considered part of the emissions systems to be warrantied for longer periods. Seven years I think? Which probably drove GM to improve components and wiring that otherwise might have been marginal at that age.
The service bulletin was to add the relay to address the no-start situation due to the heat soak on the starter/solenoid. It was a retired Chevy rep that stated that in a forum I was reading. Don't know if there was one for Pontiac or not but the issue was GM wide since they all used the same starter/solenoid design. It worked because it boosted the voltage to the S post on the solenoid.
#38
Okay, refresh my memory. I might be wrong, but I think I remember changing the starter field coil from a 2 coil to a 4 coil for heat issues when I was a tech back then.
My first new car was a '71 Z28 and quite often it would not crank. Took it in under warranty several times and they never figured it out. Fortunately, it was a 4 speed, so I could push start as long as a friend was with me. I ended up making a jumper wire to go from the purple wire to the battery so I could start it myself. Never figured out the problem.
| The Following User Says Thank You to HoovDaddy For This Useful Post: | ||
#39
I do know that I still had the heat problem back in the day with my Camaro (with headers) even when I changed to a starter that used the spacer.
#40
I'm still seeing them offered with both long and shorter copper spacers ( Rock Auto) .. is one preferred over the other? I remember they used to designate the difference as one being "heavy duty" and the shorter spacer not. Don't see that in the descriptions now.
