Old 03-14-2022, 10:22 AM
Default 1998 Tacoma radiator
I'm having a problem finding a manual shift replacement radiator for a 98 Tacoma. Does it really matter? Can you just block the coolant ports off?
Old 03-14-2022, 10:56 AM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
What engine?
Mr_GTO's Avatar
4WD?
Old 03-14-2022, 10:58 AM
Mr_GTO's Avatar
Have you checked www.rockauto.com or www.1aauto.com (these guys are big Pontiac people, Merle Green and his son own that company)
Old 03-14-2022, 11:30 AM
It's a 2.4 4 cylinder two wheel drive.
Haven't checked Rock Auto and never heard of your second link. I'll check them out. The reason I'm asking is that I have found some mail order ones much cheaper than my local parts stores but they all show the coolant line fittings. Any problems would of course be much easier to deal with locally but I'm trying to save a few bucks here.
Old 03-14-2022, 11:40 AM
Sirrotica's Avatar
Greg, I'm not familiar with toyota trucks, but if the radiator is built like a GM is, you can definitely use an automatic radiator in a stick shift truck. I would assume the automatic radiator might actually be a little larger/thicker because of having to also cool the transmission through the coolant, where the stick radiator would have less thermal load. just an assumption on my part though, no actual knowledge.
This link suggests the radiator could be interchangeable:
https://www.partsgeek.com/catalog/19.../radiator.html
Some of the listing do differentiate manual and automatic, some don't.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-14-2022, 12:06 PM
I'm feeling like they are interchangeable also. In fact, I'm pretty sure I've done it before where the cooler just wasn't used on the replacement radiator.
This company actually mentions in their description that some radiators may have coolant lines that are not used. Can't find it now.https://mbenzgram.com/products/csf-9...iABEgLKbPD_BwE
Old 03-14-2022, 12:29 PM
Thanks for the links guys. I think it'll be ok. I suspect that the reason I can't find one that is manual specific is that there's probably no sense in making two radiators when one could apply to both trucks.
Old 03-15-2022, 04:03 AM
danz123 danz123 is offline
What engine??
Old 03-15-2022, 09:35 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Yes pretty normal to use the auto one for std. See it all the time at work, (Toyota Dealership.)
64 Lemans hardtop
4spd, buckets
The Following User Says Thank You to Lemans64 For This Useful Post:
Old 03-15-2022, 10:51 AM
Thanks for confirming that 64.
It's a 2.4 danz123.
