Old 03-19-2022, 05:51 PM
Adecco Adecco is offline
Default 1967 GTO 400 motor/4 speed trans
I have a 67 GTO 400 WT motor 670 heads (335 HP 10.75-1 CR), all the pullies, (NO INTAKE, NO DISTRIBUTOR, NO CARB) has the matching Muncie for speed trans #3885010, with linkage/bellhousing (m20, m21, m22) this came out of a 1967 GTO and motor turns over/spins over.. .. asking price and local pickup due to size is $6500 obo
I know I will get a lot of WFT and serious replies of message's but go find one with the matching trans for this price or a 1967 GTO ..
Contact me at 708-834-8733
Tom
Old 03-21-2022, 06:05 PM
updated pics
Name:	image0 (11).jpeg
ID:	586814   Click image for larger version
Name:	image0 (10).jpeg
ID:	586815   Click image for larger version
ID:	586816   Click image for larger version
ID:	586817   Click image for larger version
Old 03-21-2022, 06:07 PM
more pics
ID:	586819   Click image for larger version
ID:	586820   Click image for larger version
ID:	586821   Click image for larger version
ID:	586822   Click image for larger version
Old 03-21-2022, 06:08 PM
one pore pic
Old 03-21-2022, 06:09 PM
pic
ID:	586825   Click image for larger version
Old 03-21-2022, 06:12 PM
pics motor 67 gto
Old 03-21-2022, 06:15 PM
9786133 stamped on back of block by oil pump
Old 03-22-2022, 10:41 AM
dhcarguy's Avatar
dhcarguy dhcarguy is online now
Tail section #3846429 is early 1965 Muncie.
The Following User Says Thank You to dhcarguy For This Useful Post:
Old 03-22-2022, 11:30 AM
Default correct
correct on the tail section but it was most likely what GM did for the casting number 3885010 is for years 1965-1967 M20/M21/M22 transmission's
Old 03-22-2022, 11:35 AM
https://www.classiccoachupdate.com/f...TIFICATION.htm
Old 03-22-2022, 06:29 PM
dhcarguy's Avatar
After Feb. 65, the tail sections were all 3857584 thru 69.
Casting #3851325 is 65
Casting 3885010 is 66 and 67
Casting 3925660 is for 68 and 69
Old 03-22-2022, 06:51 PM
John Milner's Avatar
John Milner John Milner is online now
I’ve had numerous Muncies from 66-70 GTO’s that used a 3846429 tail housing. Believe all 66-70 Pontiac A bodies got the driver’s side speedometer gear location and 67-70 Pontiac F bodies got a passenger side speedometer gear location (3857584).
The Following User Says Thank You to John Milner For This Useful Post:
Old 03-22-2022, 06:54 PM
Date code on back of the '67 WT block???
Old 03-23-2022, 08:12 AM
Default DATE CODE
DATE CODE on back of block FO87
Old 03-23-2022, 04:52 PM
The person whom I got this engine from dropped off the correct exhaust manifolds for a 1967 GTO 9779032 Left side and 9779328 Right side .. also included in the price.
Old 03-25-2022, 11:29 AM
Default Price Adjustment
Price adjusted to $6000..
Old 03-29-2022, 09:49 AM
TTT...
Old 03-29-2022, 12:15 PM
Default SOLD
SOLD ...
