Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-16-2021, 02:44 PM
77 TRASHCAN's Avatar
Originally Posted by 433lemans View Post
PM sent.
You need that intake!!!
Shut it off
Shut it off
  #462
Old 10-16-2021, 08:38 PM
433lemans's Avatar
433lemans 433lemans is online now
Old 10-20-2021, 11:40 AM
M1Lover's Avatar
M1Lover M1Lover is offline
Default GONE GONE GONE
Intake is gone.
Originally Posted by M1Lover View Post
Doing a nostalgia build? You can have this for the price of shipping or pick it up free in central Arizona. P4B Edelbrock, intake needs thread repair at the temp sensor port. Send a PM if interested. Lost my shop space. Head to the trash shortly.
"If we're all thinking alike, somebody's not thinking". - Gen. George S. Patton
"Fat people make lousy revolutionaries". - Me
'67 Grand Prix 400/400 Cameo Ivory
'69 Firebird 455 BW ST-10
'69 Grand Prix J 455/400 Midnight Green (SOLD)
'66 LeMans Ex-Drag Racer Parts Car (SOLD)
'66 TOO DAMNED RUSTY GTO Project (SOLD!)
'70 Firebird Esprit (SOLD)
  #464
Old 10-24-2021, 04:47 PM
68-72 Olds A-body 10 bolt rear. 2.78 pegleg. Been under my car since I've owned it. Just pulled today. If you want to pick it up it's yours.
Sent from my moto g stylus (2021) using Tapatalk
Old 10-24-2021, 05:51 PM
Might pull the axles & measure the diam of the axle bearings...
Rear is a '68-70 Type "O" Olds, & from look of the bottom of the shock mount brackets, originally from a VistaCruiser or flat top Cutlass wagon.
  #466
Old 10-27-2021, 02:56 AM
Thanks oph. I've tried several times to ID this axle but the stamping may be wrong. It's clearly 'T1' or 'TI' but l've never been able to find that axle code anywhere for the 'O' type rear. I'll measure a bearing later today if l get to it.
Old 10-27-2021, 12:46 PM
Bearing opening measures 2.85". Code T1.
Old 12-11-2021, 07:04 PM
gobrdgo gobrdgo is offline
8 pontiac 455 rods, factory bolts with .030 L2359 trw forged pistons. I think that part number is forged. They are free. If no interest gonna toss them. Once I saw the bearing wear on this engine the while I’m here thing took over and all I re used is the crank. Go figure.
  #469
Old 12-11-2021, 08:28 PM
I started this thread almost 16 years ago. That’s nuts.
The Following User Says Thank You to gobrdgo For This Useful Post:
  #470
Old 12-14-2021, 05:05 PM
Rods/ pistons gone
  #471
Old 12-18-2021, 10:49 PM
Batman's Avatar
Batman Batman is offline
Default 78-87 G body rear heavy duty variable rate coil springs
Brand new I think these are Moog, save them from the recycle bin!
https://forums.maxperformanceinc.com...94#post6303694
Name:	lift springs.jpg
  #472
Old 03-01-2022, 01:08 AM
CatalinaMike CatalinaMike is offline
Default 58-60 370-389 Engine gasket set
Got these when i bought an engine. I have nothing that can use these so I'll send them out for the mailing cost. Best Gasket engine building set for Pontiac 58-60 370-389 Engine gasket set. If you need them they're yours
  #473
Old 03-01-2022, 02:50 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
PM sent.
  #474
Old 03-01-2022, 10:48 AM
Kingman Man Kingman Man is offline
Thankyou, yes I have an engine in progress. Let me know how much and the money will be on its way. Dan Merritt, Kingman Man, 1780 E Develin Ave, Kingman, AZ 86409.
1955 Star Chief 4 dr w ex w/c lift
1964 Comet 4 dr
1989 Cherokee 4 dr
2000 Dodge Grand Caravan w w/c lift
2000 Kia Sportage 4 dr
  #475
Old 03-01-2022, 11:01 AM
rontiac's Avatar
rontiac rontiac is offline
pm sent Batman
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
  #476
Old 03-25-2022, 12:12 PM
Scott65's Avatar
Scott65 Scott65 is offline
Default Mallory unilite photocell
I got this with the distributor I gutted to make a cam sync. Don't know if it works. If you know a method to test it, I can probably do that. Yours for shipping cost. CONUS only, I'm not dealing with international shipping to donate something... OR, I'm in the Houston area if you're local you can pick it up.
ID:	587108   Click image for larger version
'65 Tempest 467 3650# [email protected]
  #477
Old 09-01-2022, 01:14 AM
I've still got a complete 350 2-barrel engine free for the taking. I believe it's a '72. I drove it a few thousand miles with no problems. It's been in my barn for almost 20 years, but has been all together and still turns free. Has a standard-shift bellhousing and clutch/flywheel on it. Accessories (pulleys, alternator, etc.) are really ugly with surface rust and crud.
  #478
Old 12-12-2022, 11:15 AM
lrust's Avatar
lrust lrust is offline
Default 64-65 Convertible top end cap
used, good shape - don't need.
  #479
Old 12-13-2023, 11:07 AM
lrust's Avatar
Default D port Zoomies - free
1.75" OD, made by local muffler shop. pretty rough but no leaks. free if you cover shipping from 29642
The Following User Says Thank You to lrust For This Useful Post:
  #480
Old 02-20-2024, 08:29 PM
form74's Avatar
form74 form74 is offline
400 crank from a 75 481988 block
7 pistons / rods from the same block checked two one was S one was p both also said 3
8 400 rods with pistons checked two both said either 7 or L
Have had the stuff for over 10 years the block was used for a project
Pickup only in Glendale Heights IL
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
