Old 04-24-2022, 04:37 PM
bird72's Avatar
bird72 bird72 is offline
Default Tach / Clock knob ID help
Appreciate any help on ID on this knob. Scalloped around edge. IS this an early Bird Tach adjustment knob for clock? THX!
72 Bird
Old 04-24-2022, 05:00 PM
Ramairnacho Ramairnacho is offline
Yes it is
Old 04-24-2022, 05:51 PM
bird72's Avatar
Thanks RANach! I assume this is what your 70 has?
If you or anyone knows what years this is correct for (?)
72 Bird
Old 04-24-2022, 06:23 PM
22687's Avatar
22687 22687 is offline
Yes it is one of two parts. I believe 70 only. Here's another thread with more info.
https://forums.maxperformanceinc.com...59#post5225259
The Following User Says Thank You to 22687 For This Useful Post:
Old 04-24-2022, 06:43 PM
Yes it's correct 70 knob on mine.welcome
Old 04-24-2022, 08:08 PM
bird72's Avatar
Thank You so much! This clears up a mystery. I also now just found the second part of it, thanks to that link you gave. I bought this set up a couple years ago thinking it would work on the tach I had put in my 72. It was actually a tach out of a 73 I used. For some reason it would not work on that tach. I wound up using the chrome style knob that did work. Thanks again to all.
72 Bird
The Following User Says Thank You to bird72 For This Useful Post:
Old 04-26-2022, 09:06 PM
22687's Avatar
"For some reason it would not work on that tach." Yes as you found out the knobs are not interchangeable. The adj. stems are different for whatever reason. Found that out when I took the cluster apart for your tach bracket. When I boxed up the tach I thought I'd just put a chrome one on but it wouldn't fit. Tried the black one from my car and it fit. Until then I had just thought someone had lost the original and replaced it with something that fit. Then did a search and learned the black ones were correct earlier.
Old 04-27-2022, 05:10 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Trying to confirm if this is a 1970 clock. The shaft has full round threads as my other clocks here have a flat sides on the threads. The shaft also appears to have a longer shaft. It measures .950 from the clock face but I have nothing here to compare it to. There is also a 2040 stamped on the back.
ID:	589551   Click image for larger version
Go fast, see Elvis!
Old 04-27-2022, 08:31 PM
OG68 OG68 is offline
Julian date is my guess
2040 - July 23, 1970
2007 Cadillac SRX
Old 04-27-2022, 10:03 PM
necdb3's Avatar
necdb3 necdb3 is offline
That clock knob was used on T/A's and Formulas 1970- 1972. That is a very hard part to find. I believe the 73's started the chrome knob.
Old 04-27-2022, 10:23 PM
PAUL K's Avatar
It was also used in any Firebird with a clock option during the first few years of production.
You are correct about in being a hard to find part.
Go fast, see Elvis!
