Old 05-01-2022, 01:31 PM
ZeGermanHam's Avatar
Originally Posted by grivera View Post
Looks and sounds great. For sound deadener you don't have to break the bank with high-priced name brand. Two boxes of this - total of $130 -will do your floor and probably enough for your doors. Then you can move on with carpet install.
https://www.amazon.com/Siless-mil-sq...1407971&sr=8-9
Originally Posted by 64speed View Post
Thanks, I was wondering if anyone had used it!
Agree that there is zero need to buy Dynamat brand sound deadening. I used 80mil Noico brand sound deadening in my car (also purchased through Amazon), which looks to be very similar to the Siless brand linked to here. I actually liked the Noico better than Dynamat which I have used in the past. I can't speak for the Siless brand, but the Noico was easy to work with and has zero odor.
Whatever brand you go with, two boxes of 36 square feet is enough to do the entire floor pan, firewall, side kick panels, underside of dash, and the underside of the roof. I don't imagine you'll be doing under the dash now that you have stuff installed there, however. Once you get some sound deadening and carpet in there, it will be MUCH quieter.
1998 BMW 328is (track rat)
  #882
Old 05-01-2022, 03:42 PM
64speed's Avatar
64speed 64speed is offline
I bought Noico off Amazon and got enough to do everything including inside the doors. I plan to do every square inch I can. I figure it cant be too quiet especially since my wife and kids will be in it and I gotta have my tunes which is why I invested in that kick ass stereo I gotta have installed. I dont know if I ever gave the details on that. I had the factory radio gutted and converted to Bluetooth. It has a microphone for wireless calling, still has AM and FM channels and has two amp preouts. I bought a Pioneer amp and four 6x9 speakers. The amp is gonna be hidden under the seat. The original kick panel vents have been removed and a place called Norwoods in Anderson SC has already measured to fit one set of 5 way 6x9 speakers in the original vents. The other set are 5 way as well and will be fitted to the package tray. I did not want to put subwoofers and all that in it but I gotta have my tunes. Turnswitch did the radio conversion but I was told the old man died and they quit doing radios in December so I wonder how that affects warranty.
  #883
Old 05-01-2022, 04:09 PM
tom s tom s is offline
Your going to add weight and you could have cured it with a more quiet exhaust system!You might go through all that and might find you will have to change the exhaust anyway!Good luck!Tom
  #884
Old 05-01-2022, 04:30 PM
64speed's Avatar
I am not worried about weight, hell I could add another 500 pounds and it will still scare the **** out of me. I can carry a conversation in the car right now even with a big ass hole in the floor right between my wife and I. We just came back from shopping. I will be ok. You gotta pay the cost to be the boss
  #885
Old 05-01-2022, 07:42 PM
64speed's Avatar
Tom I was kidding by the way
  #886
Old 05-01-2022, 07:48 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
David I run a Pypes 3 " exhaust with 20" 2 chambers welded mufflers and they are noisy as hell . I added the 3" Vibrant Ultra Quiet resonators after the mufflers and it has made a world of difference. That's until you stab the throttle.
  #887
Old 05-01-2022, 08:33 PM
64speed's Avatar
If I can’t get my wife on board I may try that. Thanks.
  #888
Old 05-01-2022, 09:47 PM
I hate the 2 1/2 setup in my 69 bird!The drone at 2000 just sucks,I have put sound reducing mats,on my 3rd set of mufflers,same as I have on my 62 421 car which is dead quiet.At wits end!I think its the custom shorty headers that were built on the car is the issue.Tom
  #889
Old 05-02-2022, 08:11 AM
grivera's Avatar
grivera grivera is offline
I used the Noico brand in mine, but black. I was gonna suggest that but didn't see the 36 sf box so posted the Siless brand instead. I haven't experienced any odor with the Noico either.
I used this kit of hand rollers for install: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Will Rivera
  #890
Old 05-04-2022, 07:21 AM
I usually run dynomax super turbos, they are quiet. Most say they are too quiet, but don't think that's possible IMO. In the 442, 495ci, hooker super comps, 2.5 exhaust, pypes w X pipe, over the rear and out the back, no drone at any RPM, and no power reduction. You can ride with the windows down and talk to people in the back seat even.
In the GTO, same system with Goerlich Xelerators, there's a slight drone around 2000 RPM, but tolerable. Louder than the Dynomax, especially at WOT, but tolerable. I will probably swap them out for the Dynomax'. Oddly, same car, same exhaust, they were quieter with the 461ci, and no drone whatsoever at any RPM.
I think cam profile does in fact have an impact on sound and drone, especially as you go to larger displacements.
  #891
Old 05-04-2022, 09:24 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Hwy, how much power is that 442 making? I have a hard time believing there is no power loss with 2.5". I picked up 2/10 with 3" headpipes and wish I went all 3". I'm also pretty sure I was told by Dynomax that the STs start losing power past 385hp.
Chris D
69 GTO Liberty Blue/dark blue
T400, 9" w 3.50s, 3905lbs
  #892
Old 05-04-2022, 10:43 PM
Could do the math and estimate it, but honestly don't know exactly. More than 385hp, that's for sure. Bernard said similar builds were in the 575 range.
442 has the trumpet tips that go thru the bumper cutouts, to get everything to line up, 2.5" is pretty much the max. They do make a kit, but have heard it doesn't fit well, and the 3" trumpet tips look silly.
So, just like on the GTO, and the Lemans before, with the splitter tailpipes, you pretty much need to run 2.5" on those. I know the 461 made more than 550hp, and the 535 certainly makes more than 600hp.
On all those, loosing a little is acceptable for my needs. I know I can run 3" up to or even past the muffler, I may try that on the GTO, will see. 442 is my daughter's car, and she's fine with giving up a little.
  #893
Old 05-06-2022, 01:42 PM
64speed's Avatar
Ok so I have two problems. 99 and a half miles exactly , my car developed a skip so I pulled some plugs and my brothers expert "by ear" tuning had fouled 3 spark plugs. I replaced all 8 and it started running like a champ again. I got out my copy of How To Tune And Modify Holley Carbs and followed the guidelines exactly using my vacuum gauge etc and now it runs like a top but there is some collateral damage...in my exhaust tips. My once beautiful chrome exhaust tips are BLACK on the inside. What can I use to clean them out because laquer thinner on a rag aint doing it and neither is a wheel brush. Second my exhaust man pulled the connector off my sending unit when he was doing my exhaust. The little boot and terminal that connect to the sending unit is what I mean. I went to reconnect it after the exhaust was put on and the connection was not tight. I put needle nose pliers on it and tightened up the terminal that goes around the spade and got what I felt was a good connection but now my once rock steady fuel gauge is bouncing all over the place when I drive. If I sit still it gives me an accurate reading but as soon as I move its all over the place and it wasnt like that till it got jerked off the spade. What should I do to remedy these problems?
  #894
Old 05-07-2022, 12:06 PM
If your tips aren’t aluminum, oven cleaner does a great job of removing carbon.
Dr. Thomas Sowell
  #895
Old 05-07-2022, 02:56 PM
If you corrected the rich condition, the tips will clean out on their' own by driving it. Highway time does the best.
  #896
Old 05-07-2022, 05:45 PM
64speed's Avatar
How about the gas gauge
  #897
Old 05-07-2022, 06:29 PM
grivera's Avatar
Check the wire to terminal connection and the ground for bad connections
Will Rivera
  #898
Old 05-07-2022, 06:55 PM
NeighborsComplaint's Avatar
They're going to carbon up every time you use the choke. It's the nature of the beast.
Triple Black 1971 GTO
  #899
Old 05-07-2022, 07:59 PM
Sirrotica's Avatar
One of the best solvents for carbon is water.
You're never going to keep them clean though, exhaust is a by product of combustion, you ever look into a chimney, and see one that's clean? Even a natural gas furnace gets carbon in them, and it burns much cleaner than gasoline in a ICE.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #900
Old 05-18-2022, 04:45 PM
64speed's Avatar
Well after the fouled plug debacle I decided that since the oil was BLACK and smelled like gas I would change it before we change the flywheel and get it back on the road this weekend. I cut the filter open and found no metal or anything like that but the oil that came as was thin and black as tar. I assume that was from the copious amount of fuel that was dumped in the engine by my brothers genius carb adjustment. Anything else I should check?
