Old 05-08-2022, 11:07 AM
alanmay0 alanmay0 is offline
Default Serious over heating problem
This may be a long description of my problem so just bare with me. I have a 1967 GTO. The engine has just been rebuild and it runs great. My problem is that it runs really hot. So hot that I can only drive it, at the most, 10 miles before it pegs the temp. gauge at 250+. It is not the gauge I have a infra red temp gauge that I check the temp with. I check at the thermostat housing to get the engine water temp from and then agian I check at the water pump inlet where the bottom radiator hose connects to the water pump. I do get about a 20 degree drop between the two locations showing that the radiator is taking out heat. I have a Butler performance aluminum radiator with two 10 or 12 inch fans, cant remember exactly which ones. This is what the guy at Butler suggested for this car. I have each fan set up on its own relay so if one stops the other will still run. I have a 160 thermostat in the car now. I did have a 190 and there is no difference in engine temp.. I have new water hoses and I have the spring in the bottom hose. I have tested the in dash temp gauge and it is working correctly. Remember I check the engine temp with the infra red temp checker so you can actually take the gauge out of the picture. The fans are set to come on at 160 and they do. The thermostat does open at 160 also. The engine has new anti freeze set at about 60/40. The water pump is a flow kooler, which is suppose to be one of the best. I have corrected the divider plate so that there is very little space between the flow kooler and the divider plate as seen on many youtube videos. I have done a little filing on the divider plate so that the hole going to the heads lines up. Like I said the engine hits 250 degrees in about 10 miles at most on a 85 degree day. At this point I have to pull off of the highway and let the fans run for about 20 minutes to pull the heat out of the radiator water before I can go another 10 miles. Now I only did this yesterday because I went to a car show. In the morning it was cooler so I only had to stop twice during the 50 mile trip but coming home when it was 85 I had to stop several times. Will not drive it again until I can figure out the problem. This is where I am hoping someone on this site can help me. In an effort to fix the problem I removed the radiator and fans from butler and replaced with another aluminum radiator I have and installed the 7 blade GTO cooling fan with shroud but it still overheated. I can say one thing, I belive that the 7 blade fan pulls much more air through the radiator than the two electric fans. Just my belief.
When I had the water pump removed for the 5th time I removed the thermostat and housing and ran garden hose water through the opening where the water would flow from the water pump into the heads. This is on the left side of the water pump housing looking at it from the front of the car. I could see that the water flowed through the intake manifold, where the thermostat is housed, and it came out through two holes on the right side of the water pump housing. This indicated to me that there is water flow through the heads. I Also turned on the heater and the heater blower motor inside the car and it was blowing air at around 170 degrees when the engine was hot. This indicated to me that the water pump was working. Also when the thermostat opens I can see water moving in the radiator. It does not seem to flow as fast as my other GTO flowed but no was to determine flow speed, that I know if.
Now one thing that I just noticed while watching another youtube on water pumps for 67 GTO's, for the first time is that this guy opened up the water pump on his pontiac 326 engine and inside the water pump housing there were to rubber seals, I guess, one at each hole inside the water pump housing. Looked like one where the water is directed to go through the heads and the other where the water comes out of the heads back into the water pump.
I have never seen those rubber seals used before on a GTO. I owned another 67 GTO and replaced and worked on the water pump and never used the rubber seals. also when I had the engine rebuilt the rebuilder did not install the rubber seals but he did give them to me with the other parts that were in the gasket kit that were not used.
So Should I use the seals or not. Has anyone else ran into similar problems with over heating and can anyone have any other suggestions for me to try.
I think I have covered everything in this post to explain my situation. Ok for now the timing is set at the factor 6 degrees BTDC and I am running premium gasoline. I have the quadrajet carb. and I think the air fuel ratio is correct.
I was told by a guy at butler performance that I needed to set total timing at about 32 because of the fact that in Texas I can not get gas without ethanol in it. As far as I know the compression of my engine is still 10.5.
OK that's it any help or suggestion will be appreciated.
alan
Old 05-08-2022, 11:26 AM
max 93 max 93 is online now
Did it always run hot or did it just start? Might want to give more details on the engine rebuild
Old 05-08-2022, 11:49 AM
25stevem's Avatar
25stevem 25stevem is offline
Once any vehicle is moving more then a steady 30 mph on the road having fans running to move air thru a radiator should not be needed.
Above speeds of 30 mph leaves these possibilities and possibly in concert with one another.
1) restricted air flow.
2) restricted water flow.
3) coolant moving thru the radiator too fast.
3) improper air to fuel ratio at certain throttle openings/ load conditions.
4) low cylinder pressure / retarded Cam timing)
5) retarded ignition timing, part throttle / cruse timing of less then 35 degrees with vacuum advance hooked up.
6) restricted exh.
7) excess internal engine friction.
If your not running vacuum advance, therein lie’s a good part of your issue!
Since you have a thermal gun I would take the car on another drive on a road where you can pull right off once the coolant temp gets to 220 and I would jump out pop the hood and with the gun see what temp the center exh ports are reading and report back here with that info.
I would first however remove the filter and cut it open to look for signs of trouble .
I have also seen two electric fans mounted right to the motor side face of a radiator create a nice airflow restriction above 40 mph.
There must be a minimum of 2.5” between the motor side rad face and the face of the electric fan(s).
I do stuff for reasons.
The Following 2 Users Say Thank You to 25stevem For This Useful Post:
Old 05-08-2022, 11:57 AM
I bought the car and then started a total restoration not having driven it much. At the time I bought it the dash temp gauge did not work so dont know if it got how the few miles i drove it. The engine rebuild was just a normal rebuild. It appeared that the engine had recently been rebuilt. It was very clean when torn down. did not need to be bored out. So what could have been done in a normal rebuild, new bearings, rings, valve job new oil pump, fuel pump. I added aftermarket ac but have not used it because of the overheating condition. If you want to know more about the rebuild just ask questions. So what can happen during a rebuild that can cause the engine to run very hot after a few miles??? Thanks
PunchT37's Avatar
PunchT37 PunchT37 is offline
I believe those collars/seals are supposed to be there. Been too long since I saw an 8 bolt pump but the 11 bolt definitely has em.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 05-08-2022, 12:01 PM
25stevem's Avatar
I would also like to know if the car is boiling over or if you have bubbles in the rad which would indicate cylinder pressure getting into the cooling system.
PunchT37's Avatar
I have seen a lot of engines run hot after a rebuild. But, yours does seem excessive. Tight piston to wall clearance and rings can add a lot of heat until broke in.
Old 05-08-2022, 12:08 PM
george kujanski's Avatar
8 bolt or 11 bolt water pump?
A 8 bolt pump (standard on a '67 I believe), has 2 extra pieces, a housing plate and a divider plate. The clearance should be minimal from the vane edges to this housing plate. it forms the rear cover of the pump housing. The divider fits midway between the pump casting and the the housing plate; it's purpose is to "divide" the flow from the pump to each bank. I don't know if there are tubes or if there is a rubber seal.
If it's a 11 bolt, there is no "divider" plate; the outlet of the plate is forming to contact the outlet tubes on each bank and the face of the tubes has the rubber seal. The clearance from the vane edges to THIS plate should be minimized as you say.
George
Old 05-08-2022, 12:19 PM
Restricted air flow. I removed the electric fans and the radiator they were attached too and replaced with the aluminum radiator that came on the car and installed the 7 blade clutch fan and drove it and it still overheated
restricted water flow. I know that there is water flow because i put the garden water hose into the hole where the water pump would force the water into the head and the water flowed across the intake manifold and also flowed out the hold in the water pump housing after leaving the driver side head. I do not know how fast this flow should be but it seemed to flow out ok.
Like I said there is at least a 20 degree temp drop from the temp at the thermostat housing and the temp at the water pump inlet from the bottom radiator hose. The guy at butler performance stated that 20 to 30 degree drop is the most that a radiator could reduce the temp.
the timing is set at factory 6 degree BTDC with the vacuum advance disconected and plugged.
has a new exhaust 2.5". I did forget to say that when it was rebuilt the man did plug the exhaust crossover in the intake manifold so the exhaust does not flow through the intake manifold.
cant speak about excess internal engine friction and do not know how to check it. I do know that getting ready to set the distributor in the block the spark plugs were out and the engine seemed to turn over easy enough.
I am running vacuum advance and it is working.
what filter do you want me to remove and cut open. the oil filter?
I do not believe there is a 2.5" space between the radiator and the fans. This set up was sold to me by butler performance for this car it came with the fans connect to a fan shroud. again I switch to the 7 blade fan with shoud and it still overheated.
I drive the car and check temp of middle exhaust and report that back to you.
so do you know about using the rubber bushing in the water pump between the divider plate and the inlet and exit of the head holes.
Old 05-08-2022, 12:21 PM
Good question I forgot to mention that I did rent the tester from the auto parts store and check for exhaust fumes in the radiator. the blue liquid did not turn yellow meaning that there was not exhaust in the anti freeze. No the car never boiled over.
Old 05-08-2022, 12:23 PM
My water pump has the two dividers and I did my best to lesson the gap between the divider and the pump itself.
Old 05-08-2022, 12:25 PM
Mine is an 8 bolt
Old 05-08-2022, 12:26 PM
PunchT37's Avatar
6 degrees is too low for anything not stock. Bring it up to 12 and see what happens.
Old 05-08-2022, 12:30 PM
I will write this suggestion down and try it also. thanks. I have really tried everything I can think of. I am at my witts end. Out of ideals or things to try. The temp gauge just steadly climbs till it pegs out.
Old 05-08-2022, 12:59 PM
Cliff R's Avatar
Cliff R Cliff R is offline
What pistons were used during the "rebuild"?
What camshaft?
Was the camshaft degree'd or just installed dot to dot?..
Old 05-08-2022, 01:02 PM
The cam shaft is basically stock, maybe just a little bit above but not noticeable. As far as the pistons go they did not replace the pistons this time because it has just recently been rebuilt, unknown to me, so they just honed out the cylinders and replaced the rings. I will check with the rebuilder tomorrow for more specific information
Old 05-08-2022, 01:05 PM
25stevem's Avatar
Here is what should be present in the 67 water pump set up.
It would be a good thing to know how much cranking compression the motor is making.
Yes, cut the oil filter open.
TB1's Avatar
TB1 TB1 is offline
This, and as mentioned in Post #3 with out the vacuum advance connected and working the cruise timing would be very low with 6° initial and whatever mechanical advance the distributer is producing at the engine speed while driving down the highway. As an example full advance of say 20° may not be fully in until over 3000 rpm. so cruising around at say 2500 rpm you may only be seeing 6+15=21° total as an example
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 05-08-2022, 01:11 PM
OK I have to make one major correction in my narrative. I bought the car in Florida in December on 2021. It was in ugly shape and needed major restoration work. It had a aluminum intake manifold and a elderblock carb on it. It had an aluminum radiator with one 12 inch cooling fan. The engine was horrible looking so that is why I decided to take it out and have it rebuilt, repainted and then we sanded and repainted the engine compartment. I did drive this car from Florida To Texas, about 750 miles with no over heading issues that I was aware of. At this time the temp gauge was not working so it always read all the way to the cool side. turned out it was the sending unit was bad. So taking this into consideration something must have changed during the rebuild that is now causing the engine to run really hot. I will change this info in my first post. sorry for this.
really hope someone can help me figure this out so that I can drive the car.
thanks again.
Old 05-08-2022, 01:20 PM
OK this picture does not show the use of the two rubber spacers/O rings or what ever. see attached picture
