Old 05-15-2019, 11:42 AM
Default 1972 400 block .060 $300 with N crank
1972 400 block rough bored for .060 over. It had some pitting in one hole I wanted to be sure it was ok for .060 over and it is. Comes with the original N crank for this block and it’s standard. $300.00 pick up only.
Old 05-15-2019, 06:14 PM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
That's close to all you can go. You would need to sonic check the block to see if you can go bigger or you would need to sleeve the block.
Old 05-16-2019, 10:54 AM
That’s all it needs to go finish hone line hone and assemble. Going .060 over is not a big deal.
Old 06-21-2019, 02:07 PM
Norwalk
Old 12-24-2019, 11:46 PM
Bump
Old 07-23-2021, 06:31 PM
Norwalk
Old 09-25-2021, 08:43 AM
Bump
Old 01-27-2022, 10:20 AM
I have a complete set of.065 forged pistons, pins, rings also for this build if anyone is interested before I start on it myself. Pistons are 21cc Dish $850 for block crank and piston kit.
Old 05-08-2022, 06:41 PM
Bump
Old 08-10-2023, 04:54 PM
Bump
Old 02-15-2024, 05:50 PM
Bump
Old 08-04-2024, 12:31 PM
Bump
Old 04-04-2025, 03:01 PM
Bump
Old 05-04-2025, 04:33 PM
Bump
Old 09-09-2025, 10:08 AM
Bump
Old 04-27-2026, 06:33 PM
Bump
