Old 05-14-2022, 09:50 AM
brad01 brad01 is offline
Default 69 GTO not even 1 year from paint and body work premiere shop Indiana
69 GTO not even 1 year paint and body work. What would cause this?Click image for larger version
Old 05-14-2022, 10:39 AM
6869GTO's Avatar
6869GTO 6869GTO is offline
If your pic is of the rear window panel to quarter on a vert it is a common area to crack. It is originally a leaded seem and different shops repair area in different ways.
Leo
Old 05-14-2022, 10:41 AM
Right side on quarter near deck lid .
Old 05-14-2022, 12:27 PM
I am not sure if the factory filled the seam for his exact reason.
I had my body shop simply smooth the leaded groove and paint that.
Old 05-14-2022, 12:38 PM
72projectbird's Avatar
I'd bet the seam was filled with body filler, and the heat cycles and natural flexing of the vehicle caused it to split.
Usually if I'm filling those seams, I'll weld them together and grind it all smooth.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 05-14-2022, 12:45 PM
vertigto's Avatar
vertigto vertigto is offline
That wouldn't make me very happy after all that work was done. What did the shop say??
Old 05-14-2022, 01:03 PM
I just noticed this today . I sent him an email and a picture . Told him I will be up next week.
Old 05-14-2022, 01:04 PM
Garage is heated and a/c
Old 05-15-2022, 12:17 AM
turbo69bird's Avatar
If it’s not gonna be leaded kitty hair glass type filler then a filler over that like icing works good. But I’ve seen lots of drag cars crack like that so flexing is likely the root cause but could be shrinkage too.
960 HP @ 11 psi, 9.70 at 146.
Old 05-15-2022, 10:13 AM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
Feeling underneath the crack might give you a clue. If the camera angle is what I think, it's kinda far from the factory seam. However it doesn't rule out a thick repair or patch in that area.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
Old 05-15-2022, 12:56 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Thats not the seam. Seam is a couple inches farther in from the corner of the glass
Old 05-15-2022, 01:39 PM
400 4spd.'s Avatar
That IS the lead seam, and I stole a picture from the GTOForum to prove it. 1968 GTO.
Now you can see why they crack, especially if moisture ever creeps under the edge of the lead. I melt them out, sand blast them, weld them solid and build with weld. Forget any type of filler to hide cracked lead.
Name:	5602 crack under lead.jpg
Old 05-15-2022, 02:33 PM
tjs72lemans tjs72lemans is offline
My 72 Lemans vert was mostly painted and apart when I bought it. Never driven yet. As I was going over the restoration and going to paint some pieces, I noticed a crack in paint like that. Other side was just starting to do the same. Ground down, melted the lead out, made a patch to lay in there just below the surface, welded in and smoothed over with a skim of filler. Both sides. Had to repaint the whole dang car. All good after paint now.
Old 05-16-2022, 10:13 PM
I just had to repair that same seam on my car because it was leaking water into the trunk. Had to pull the vinyl up.
A fabricated that area on my car back when I was replacing the rust and spot welded the flanges from inside. I then finished the topside with Metal 2 Metal filler... That was the wrong thing, obviously.
Sent from my moto g stylus (2021) using Tapatalk
Old 05-17-2022, 12:51 PM
n20ta2's Avatar
n20ta2 n20ta2 is offline
I welded mine solid under the glass then used urethane seam sealer in that gap to keep it looking original. Still Crack free 1 year later
1969 GTO street strip project 11.1 forged 461, highport heads
1995 Trans-am 420 ci sb 14:1 compression 9"ford
9.89@132 1.34 60ft SOLD!
Old 05-17-2022, 06:16 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
I've done the same on the last two cars I've done. Hoping to stop that crack from happening.
Old 05-18-2022, 12:53 PM
00fxd 00fxd is offline
I used to pay attention to such things and as I recall, for some reason, that seam in convertibles was filled and hard tops was left a groove. And they were always cracked. Does anyone else have that recollection?
The Following User Says Thank You to 00fxd For This Useful Post:
Old 05-18-2022, 05:17 PM
69gtocv 69gtocv is offline
I agree, my 69 and 72 convertibles are/were both filled, my 68 hardtop is a groove
