Old 05-19-2022, 11:45 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default My new oil pan...
I had no idea Stefs even built us a pan until I saw a post a while back by Dragncar...
Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
Old 05-19-2022, 11:55 PM
turbo69bird's Avatar
That’s a sweet pan I didn’t know they made one either
What’s the side bung for up behind the starter ? Almost looks like a turbo drain back location.? Or is it for dry sump?
960 HP @ 11 psi, 9.70 at 146.
Old 05-20-2022, 12:10 AM
69Goat1's Avatar
It’s an oil drain back from my Eheads. The other side will have one as soon as we mock it up and see where we can put it...
The Following User Says Thank You to 69Goat1 For This Useful Post:
Old 05-20-2022, 02:34 AM
Dragncar Dragncar is offline
Nice pan. I had them put in a provision for a dipstick on pass side and a 1/8" bung with baffle just below pan rail for vacuum fitting. I should have had them put in a oil return fitting just forgot to ask. They sent me some weld in bungs if I want to do it myself. But running High Ports so I do not think I need one.
I made my own oil pump pickup for a pump I enlarged to .915 on suction side.
Did you buy the Steffs pickup ?
Are you planning on running a gasket or just use The Right Stuff and no gasket like some do ?
One thing I have done is buy I-Js teflon crank scrapper to add to it all. You can actually touch the crank with this scrapper. Kind of expensive at 230$ but if it gives me more power its worth it.
I-J told me this scrapper can add 3, maybe 4% horsepower which is a lot if you think about it. A regular steel scrapper gets you 1-2% more horsepower he said.
Aluminum block, she is going to be badd @$$.
Old 05-20-2022, 07:39 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Nice looking pan.
Looks very similar to the pan I got from Moroso.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
The Following User Says Thank You to BDHABT For This Useful Post:
Old 05-20-2022, 11:34 AM
Hooter's Avatar
Hooter Hooter is offline
I ran a similar pan from them for years. Nice piece.
67 Bonneville ragtop
Old 05-20-2022, 07:29 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
I need a pan , looks nice . Does that pan fit stock chassis/ crossmember A body cars ? How long did you have to wait for pan ?
505 CID, 3560 lbs,Tiger heads, NA.
8.99@149.8 mph, 1.29 60', stock suspension
Old 05-20-2022, 09:02 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
I had one on my tube car. It was a very nice piece. They make good stuff.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 05-20-2022, 10:06 PM
Looks like the same pan I bought from them. Its for a stock chassis, race pan with big kickout on passenger side, trap doors and built in windage tray. Looks like his has the covered bung for vacuum fitting in the same spot as mine too.
They will not have the built in crank scrapper like a Canton. But how close could you get a crank scrapper built into the pan anyway? Just put in a pan rail located crank scrapper on the kickout side and you have a better scrapper, clearanced right vs the Canton .
I first called Canton but it was during Covid and the wait time was huge.
Called Stan at Steffs and my pan took 3 weeks. Great to deal with.
Old 05-21-2022, 11:45 AM
69Goat1's Avatar
I got the pickup from them. We are gonna use the right stuff on it.
Old 05-21-2022, 11:48 AM
69Goat1's Avatar
Yes, fits stock chassis A body. Mine was quoted to take 2 months but in actuality it was nearly a 3 month wait due to materials and labor issues.
Old 05-21-2022, 06:56 PM
69goat1 , Dragncar , thanks for the info . I made a kickout for the canton 452 pan and have the Teflon screen from Stef's, still working on it . Might just order the Stef's pan and save this one for a future project .
Old 05-21-2022, 07:07 PM
77 TRASHCAN's Avatar
She's been Bad$$ for about a year!!!
Johnny, is the blower going on it???
Hope you can make Great Bend. Last year was pretty ho-hum with that long oil clean up...
Shut it off
Shut it off
Old 05-21-2022, 11:31 PM
69Goat1's Avatar
No on the blower...still too much compression and I want it pretty simple...should be stouter this time out since my intake lost about 2 lbs...
Hoping to make Great Bend and the POCI race in July in Tulsa...
