Old 05-28-2022, 02:39 PM
65gto69's Avatar
65gto69 65gto69 is offline
Default 1965 GTO 4 speed with Doug's headers z-bar issue
Hi, NEED HELP!!!!!!
Putting the 4 speed back in my 65 GTO and have Doug's round port headers installed. Doug's states that the headers will work with 4 speed floor shift and should use the factory z-bar.
I have the factory z-bar but the lower lever of the z-bar will not clear the last header tube. I am on the ball stud as far as I can go but the lever is hitting the last tube by about 1/4" so the z-bar will not rotate.
What is wrong and what can I do to fix?
Thanks for your help,
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 05-28-2022, 06:16 PM
I had to find another Z-Bar and remove the lever that interfered and move it so that it cleared. Then I used a Heim pivot mounted on the Z-Bar to push the clutch fork rod, (to correct for the offset). 64 GTO body and Muncie trans at the time.
Old 05-28-2022, 11:47 PM
AG's Avatar
AG AG is offline
I think you have to use the later '68-'72 Z-bar for your car that had the bolt into the block for those headers instead of the screw in stud/ball. I remember reading something like that years ago but I'm not sure now.
The Following User Says Thank You to AG For This Useful Post:
Old 05-29-2022, 08:08 AM
Scott Stoneburg's Avatar
Doug's has a disclaimer on their site about this. You need the later Z-bar to clear like AG mentioned
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 05-29-2022, 08:49 PM
Richie Hoffman's Avatar
i put doug’s headers in half dozen early gto never had a problem last 2 sets within last 2 yrs i had to cut lever off zbar and weld . they changed there design
2008KRE Q16 Winner
Old 05-30-2022, 09:39 AM
ANDYA ANDYA is offline
Does anybody know if the Doug’s D-ports have the same problem? Thinking of getting a set for my 65.
Old 05-30-2022, 08:15 PM
Gary H's Avatar
Gary H Gary H is offline
I've never run into a issue with the D ort Doug's headers. I've installed multiple sets on customer's cars
Old 05-30-2022, 09:56 PM
Can you cut and reroute one tube?
Old 06-04-2022, 09:15 PM
65gto69's Avatar
I managed to get the original z-bar in with the doug's round port headers. I removed all the screws from the headers so they were not attached to the block anymore. I pulled the bolt from the drivers side motor mount and jacked up the motor. At this point I was able to get the z-bar on the block ball and get it around the header tube. I also had to remove the zerk fitting on the z-bar because that faced down and stopped the header from tightening against the head.
Block is bolted back down to the frame, headers are bolted back to the head and z-bar moves with no issues.
Thanks for the suggestions
Mark
Old 06-05-2022, 10:32 AM
I should mention that I was trying to install JR Race Headers (Flat Collectors)
on my 64 GTO. NOT Doug's headers. Sorry for the incorrect info on this Dougs headers thread.
