where do these clips go?
Also Is the for cornering lights? something else?
I believe the retention clips catch the brake pedal support bracket. The wire harness with fuse in line looks like a tach feed.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Yep those clips go into holes in the stamped steel column support. The curved one is pretty easy to find .... I gotta admit I put the others in whatever hole seemed most convenient (same way I found my wife).
The 69 Assembly Manual is almost helpful ... but not very, since a lot of the dash is different. I was using an old harness so it kind already had a "set" which helped locate the appropriate hole. I remember someone in the 68-69 section posted some pretty good underdash photos ... so someone knows the exact location.
| The Following User Says Thank You to dataway For This Useful Post: | ||
Gotta be picture somewhere
thanks fellas |
I found this in my files.
From the 68 Factory service manual. Chapter 12, page 12-23. If you look at the close up you can see how the harness is attached to the pedal carrier The blue 69 assembly manual has a number of pages for the 68 Tempest. This is one of them. Shows the dash wiring instructions.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
| The Following User Says Thank You to OG68 For This Useful Post: | ||
Yep .. THAT page from the 68 service manual is what I used to find the two holes.
Thanks |
yes.
Look at the close up, it has guidelines to indicate which holes to plug the harness into
After seeing this thread, I went out and looked to see where my harness was and noticed it was just laying loose in there. I know I changed out the Boyne turn signal years ago on it. So you're saying this should go over the top of the pedal carrier from the drivers side and not from the passenger side like this is? It must, because I don't have the length to get it up there and into the hole from this side
OG ... could you email a copy of that blue page, looked through all the stuff you've sent me and I don't think I have that one
![]() 69gtocv I think it the harness from the column should go around to the top of the column from the passenger side because the hole for the connector pin is on the top passenger side of the pedal carrier.
I'm World's Best Hyperbolist !! Last edited by dataway; 06-01-2022 at 02:13 AM. |
Is this your photo turned the right way?
I bet there are a bunch of 68-69 readers that have done a super nice job underdash. Because if we have to go there again it darn well better be clean& neat, in proper oder so we can remember what modofications got added.
I have resorted to labeling non-stock wires with pen on maskingtape labels: Speedo-alert, Fuel Pump, Elec Fan Manual wire, HEI Manuel wire, Power Ant, Rear Kill Switch to Block relay. I can figure out the Vacuum gauge hose and 12-Volt Gauge
Thanks for the reminder. I've added a few circuits myself that I need to I.D.
I labeled everything when I was testing my harness on the bench .... then decided to leave them all there after installation ... which was good cause half of it I ended up disconnecting and reconnecting for one reason or another.
Everything looks different when you are upside down
Dementia setting in?
![]() My dad suffered from dementia. One of his reoccurring hallucinations was that the house was upside down.
Yes, I'm looking up from the floor to the passenger side of the column
