I’m in need of a couple of things.
The vertical molding that looks like a curved L behind the quarter glass is missing a clip. The clip attached to the molding and has a head that pushes into the quarter panel itself. Is the clip in this pic correct? Is the kit for that molding? The one between drip rail and quarter panel. Also I can’t seem to find nuts that secure the hood scoops to the hood. |
I think that kit is for the molding from the L shaped piece, back to corner piece (the two nuts) and across the panel at the top of the trunk.
I didn't even know that L shaped piece had a clip, thought it was just the two screws ... so I probably need the clips too. I bought a box of 50 speed nuts from Aveco (?) ... seems to fit many applications that use them ... I'll check and see if they fit my scoop inserts, I still have a few of the original nuts attached to them. Places like McMaster have a good selection of speed nuts of various sizes ... but you gotta figure out what size you need.
I'm World's Best Hyperbolist !! Last edited by dataway; 06-07-2022 at 05:07 AM. |
The nuts I'm going to use to replace missing OEM scoop nuts are:
Auveco PN 3404MC 3/16 stud size 1/2" OD flange 3/8" Hex Head Tested them and they seem to fit fine on the scoop threads. Don't see the equivalent on McMaster, or anyone selling less than a full box of the Auveco. PM your address and I will send you a dozen of them ... I bought the smallest box ... 100 of them I'll see if they make it through in a letter envelope.
