70 GTO PARTS
These are all left over from my restoration price doesn’t include shipping. If you are interested my email is Tim_Larsen76@hotmail.com Single groove crank pulley- $15 480509 XS Rear bumper brackets frame to inner brackets. Left is bent a little. -$20 Fan clutch-$20 477957-PC Harmonic balancer-$15 Trunk latch assembly missing one bolt-$10 Air cleaner elbow (x2) $5 each Aftermarket front park light/turn signal sockets - $5 Rear view mirror bracket and black cover- $15 New aftermarket window cranks -$20 Rear seat ash tray -$10 Ignition coil bolt and strap (AMK G-7638)- $10 Throttle bracket to intake (AMK G-7628) -$10 Seat side panel screws (AMK- G-6656) - $10 Seat back panel screws (AMK G-6654) -$10 Water neck bolt and hardware (AMK G-7594)- $10 Hood scoop insert fasteners (AMK G-7410)- $10 Console bracket screw kit (inline tube #INL12497)- $10 Heater hose clam kit (inline tube #INL10500)- $10 Valley pan bolts (inline tube #INL10128)-$10 Radiator hose clamps (#INL11303) Starter wire heat shield non ram air- $10 Hood release assembly (release lever attach point is bent) Console lid hinge -$10 Headlight bulb retaining ring - $5 Air cleaner to valve cover vent tube - $10 Coil (unknown condition) 238 BR - $10 Center console mounting bracket - $10 Fuel pump (unknown condition) Headlamp housing - $10 |
Pictures
Fan clutch and vent tube sold. I am open to offers. Thanks
GTO PARTS
These are all left over from my restoration price doesn’t include shipping. If you are interested my email is Tim_Larsen76@hotmail.com Single groove crank pulley- $10 480509 XS Rear bumper brackets frame to inner brackets. Left is bent a little. -$20 Harmonic balancer-$10 Trunk latch assembly missing one bolt-$10 Air cleaner elbow (x2) $5 each Aftermarket front park light/turn signal sockets - $5 Rear view mirror bracket and black cover- $10 New aftermarket window cranks -$15 Rear seat ash tray -$5 Ignition coil bolt and strap (AMK G-7638)- $5 Throttle bracket to intake (AMK G-7628) -$5 Seat side panel screws (AMK- G-6656) - $5 Seat back panel screws (AMK G-6654) -$5 Water neck bolt and hardware (AMK G-7594)- $5 Hood scoop insert fasteners (AMK G-7410)- $5 Console bracket screw kit (inline tube #INL12497)- $5 Heater hose clam kit (inline tube #INL10500)- $10 Valley pan bolts (inline tube #INL10128)-$5 Radiator hose clamps (#INL11303) Starter wire heat shield non ram air- $10 Hood release assembly (release lever attach point is bent) $5 Console lid hinge -$10 Headlight bulb retaining ring - $5 Coil (unknown condition) 238 BR - $10 Center console mounting bracket - $10 Fuel pump (unknown condition) Headlamp housing - $10 |
Still available
Ill take the crank pulley where do I send cash?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Message sent
I'll take the 2 air cleaner elbows. Email sent.
Don't rush me - it's only year 20 of the 3 year restoration! 68 GTO convertible YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track, P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways C1 224 Triple white |
Still available. If anyone is interested I am open to hearing an offer for everything.
Parts in Bold are new in package Rear bumper brackets frame to inner brackets. Left is bent a little. -$20 Harmonic balancer-$10 Trunk latch assembly missing one bolt-$10 Aftermarket front park light/turn signal sockets - $5 Rear view mirror bracket and black cover- $10 New aftermarket window cranks -$15 Rear seat ash tray -$5 Ignition coil bolt and strap (AMK G-7638)- $5 Throttle bracket to intake (AMK G-7628) -$5 Seat side panel screws (AMK- G-6656) - $5 Seat back panel screws (AMK G-6654) -$5 Water neck bolt and hardware (AMK G-7594)- $5 Hood scoop insert fasteners (AMK G-7410)- $5 Console bracket screw kit (inline tube #INL12497)- $5 Heater hose clam kit (inline tube #INL10500)- $10 Valley pan bolts (inline tube #INL10128)-$5 Radiator hose clamps (#INL11303) $10 Starter wire heat shield non ram air- $10 Hood release assembly (release lever attach point is bent) $5 Console lid hinge -$10 Headlight bulb retaining ring - $5 Center console mounting bracket - $10 Fuel pump (unknown condition) $10 Headlamp housing - $10 |
Thanks for the pulley!!
Have pictures if you want to see something first.
Parts in Bold are new in package Rear bumper brackets frame to inner brackets. Left is bent a little. -$15 Harmonic balancer-$10 Trunk latch assembly missing one bolt-$10 Aftermarket front park light/turn signal sockets - $5 Rear view mirror bracket and black cover- $8 New aftermarket window cranks -$10 Rear seat ash tray -$3 Ignition coil bolt and strap (AMK G-7638)- $3 Throttle bracket to intake (AMK G-7628) -$3 Seat side panel screws (AMK- G-6656) - $3 Seat back panel screws (AMK G-6654) -$3 Water neck bolt and hardware (AMK G-7594)- $3 Hood scoop insert fasteners (AMK G-7410)- $3 Console bracket screw kit (inline tube #INL12497)- $3 Heater hose clam kit (inline tube #INL10500)- $5 Valley pan bolts (inline tube #INL10128)-$3 Radiator hose clamps (#INL11303) $5 Starter wire heat shield non ram air- $5 Hood release assembly (release lever attach point is bent) $5 Console lid hinge -$5 Headlight bulb retaining ring - $3 Center console mounting bracket - $5 Fuel pump (unknown condition) $5 Headlamp housing - $5 |
Still available
