Old 06-11-2022, 07:45 PM
abefromen's Avatar
abefromen abefromen is offline
Default sway bar bushings
Anyone know a part number for 1-1/4" rubber front sway bar bushings that fit original brackets? Bought some ac delco bushings a while back and they were way too tall couldn't get the bracket back on the frame.
Old 06-11-2022, 08:08 PM
pontiacstogo's Avatar
pontiacstogo pontiacstogo is offline
I had the same problem recently. Ended up just going with the Energy Suspension bushings and aftermarket brackets. I saved my OEM brackets in case I ever want to go back to stock.
Some info. here;
https://forums.maxperformanceinc.com...d.php?t=857634
Peter
1974 Trans Am, 400 4-speed, 3.42 rear.
The Following User Says Thank You to pontiacstogo For This Useful Post:
Old 06-11-2022, 08:35 PM
abefromen's Avatar
Some info. here;
Do you remember the part number of those delco bushings? I tossed the box from the ones I have and want to check something.
Old 06-13-2022, 06:21 AM
Trevor78 Trevor78 is offline
#15704513 or #472115 perhaps.
Old 06-16-2022, 01:24 PM
Went through this a month ago & I do NOT need Energy Suspension crap... been there!
Ended up finding black rubber front bushings through local independent NAPA.
O'Effys manager told me they have pretty much dumped MOOG & ordered black rubber ones for me in their Precision line. Even gave me a flier on their move to Precision chassis parts. unfortunately, ordered the part # for black rubber bushings & they kept coming in a light blue color/we kept sending them back to the warehouse.
Old 06-16-2022, 01:29 PM
dataway's Avatar
dataway dataway is offline
Every rubber sway bar bushing I've seen for years is too tall. I ended up just shaving them off on the flat side till they would fit. Still very tight, but at least they wouldn't strip out the frame trying to put them in.
Old 06-18-2022, 10:26 AM
abefromen's Avatar
after checking my parts book which is what I should have done from the start, the correct rubber bushing for the 1 1/4" front bar is 472118. They fit perfectly to the original brackets and even better yet they are all over ebay for dirt cheap.
The Following 2 Users Say Thank You to abefromen For This Useful Post:
Old 06-18-2022, 11:04 PM
wheels wheels is offline
If it's for a pontiac..............
A, B, G body is 472118 Insulator, Frt Stab Shft, (2 rib, 30.0 mm hole)
F body is 482331 Bushing, Frt Shft, (1 1/4" I.D.) (1.56" Wide)
Old 06-19-2022, 08:45 AM
abefromen's Avatar
76-81 Pontiac chassis and body parts catalog July 1987
79-81 F W/TRANS AM AND FORMULA 472118 Insulator Frt Stabilizer shaft 30.0 MM hole 2 rib
Old 06-19-2022, 05:46 PM
My bad.......Thought you had a 78 or older.
Old 06-20-2022, 08:12 AM
dataway's Avatar
What is the GM part number for a 68 A body with the standard sway bar?
All of the aftermarket pieces are too tall.
