EFI Tech All things EFI and making classics modern!
Old 07-04-2022, 08:54 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Originally Posted by djustice View Post
If it was a short, would that not blow the new fuse too?
Well, it didn’t just “let go”. Something put greater than 30 amps through that line or the commensurate amount of resistance/ heat to melt the fuse.
Very well could be something that’s intermittent or “brewing”. I chased an issue where my engine would intermittently decide it didn’t want to shut off. Weeks of trouble shooting including replacement of key switch ect. Finally grabbed a thermal imager camera and found a mass of melted wires right after the engine bay wire harness block. Would never have found it without the camera. Point is, we know several things. 1. A 30 line fuse blew leading to a micro processor. 2. That micro processor is now wonky. 3. Power spikes and or heat kill micro processors. 4. Micro processor’s don’t create electrical charges.
Coincidence? Perhaps but I would focus my attention on your work, not the company’s.
Hope you get yourself up and running soon!
Happy 4th!
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
