![]() Quote:
Sent from my SM-N950U using Tapatalk |
Didn't read through it all but an 066 cam would t take a 4 barrel... it's punchy with half throttle but if u dump it it will drown.. personal experience..
At 18 I pulled a 68 2 Catalina motor dropped it in a firebird and added a 4 barrel intake and carb... total fail.. |
I had a '67 wagon as my first car back in 1974 and did the same as you are doing. Q-jet, 4 barrel stock intake and dual exhaust. New timing gears and chain. Shift kit in the trans and spring kit in the distributor. Ran better but the 2.56 rear gear really held it back. It would go to 60 mph in 1st and 100 in 2nd gear. Stop watch 0-60 in 9 seconds. I was looking to swap the rear axle assembly to one with a 2.93 or 3.08 gear setup, but I was rear-ended at a traffic light and the car was totaled.
The Following User Says Thank You to mrmark1957 For This Useful Post: | ||
Scott, I think that it was your lack of experience / knowledge at age 18 that made your 2bbl to 4 bbl adventure a flop, especially if it was Q-Jet swap over you did!
If nothing else assuming having in the ball park jetting conditions and having full throttle available the car should have had better drivability at low speed and at least 10 to 12 more hp. I know that would have been the case for me!
I do stuff for reasons. |
Here are some dyno runs on a couple different intakes.....
https://m.youtube.com/watch?v=9AfeMtpi5pc In one of the videos he tested a Pontiac 2bbl intake as well......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Start with the gears, it'll make a huge impact.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
I used to own a 67 Catalina 2 door Sport Coupe with a 325 HP 400. It had a Carter AFB and dual exhausts with a 2.41 rear. The turbo 400 trans would shift out of 2nd gear at 90 mph. I learned 35 years after I sold it that Pontiac only made 1300 of that model.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
The Following User Says Thank You to track73 For This Useful Post: | ||
![]() Quote:
The 2GC was pulling 7” vacuum at WOT!! That’s enough to start kicking in the vacuum advance. If you already have the set up I see no reason not to throw the Q-jet and intake on. It’ll only cost $25 in gaskets and a few hours of your time. You’ll get more power AND better MPG’s when cruising.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
The Following User Says Thank You to TCSGTO For This Useful Post: | ||
Those Holder videos are informative, and I like them, but man why do so many of these guys doing these videos have to so over animated!
Gez, it’s like he drank a 6 pack of Red Bull 20 minutes before the video shoot! I mean I like that he talks fast enough to get a lot of detail into the video, but to use a automotive term please throttle it back a little will ya!?
I do stuff for reasons. Last edited by 25stevem; 07-24-2022 at 12:15 PM. |
Track73, not only low numbers with the the AFB carb for that year, but those 400s still used the 389/421 type heads also!
[QUOTE=25stevem;6359304]
Gez, it’s like he drank a 6 pack of Red Bull 20 minutes before the video shoot! People that know him say that’s just his natural personality. Certainly is enthusiastic about his work.
[QUOTE=TCSGTO;6359370]
![]() Quote:
![]() Quote:
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather Last edited by Formulabruce; 07-24-2022 at 06:49 PM. |
![]() Quote:
I could gain 9 HP with a sharp tune up, bringing the timing in sooner than stock, and richening up the carb and still run pump gas. I would guess that there is something fundamentally wrong with the OPs engine for it to be such a slug, I worked in a Pontiac dealership in 1970, those cars weren't as slow as he's describing his to be. I have seen some Pontiacs that someone changed the timing gears, and chain, that were 1 tooth retarded, and run like he's describing. They'll run smooth, but have no low end power whatsoever. Reset the timing gears, and it runs like a different car. Cutting dishes in pistons is pretty expensive when you can go with a larger CC combustion chamber, and run the stock short block with flat top pistons, but I tend to be practical, and try to save money, especially when it's my money. I've used Pontiacs from 326 to 455 in daily drivers, used them in Jeep Wagoneers and Jeep tow trucks, plus raced them on oval tracks for years, they aren't slow unless there is something wrong with the internal engine components, or the tune up is way way off. Almost all of my vehicles that were driven on the road would run on pump gas, and were under 9.5 compression ratio. A few of my GTOs were factory rated at 10.5 to 1, and the race car was 12 to 1. I got a lot of work done with relatively low compression Pontiac engines over the last 50 years. All had iron heads. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
A very smart guy with boost. Tom V.
![]() Quote:
#38
I grew up with a 66 Catalina station wagon. 3 on the tree, manual brakes. It had a 10-1 389 in it and my dad went to the junkyard and put a AFB intake and carb on the old girl that got us from CA to Oklahoma twice.
It ran great, got 20 mpg on trips. Still have the intake and carb. I have 2 AFB intakes, one is flat and one is more of a high rise. |
The Following User Says Thank You to Dragncar For This Useful Post: | ||
#39
![]() Quote:
ALL Horsepower is calculated, even at the dyno, its Never measured. You have a nice car, hate to see it get into "mission creep" and not enjoyed..
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
#40
![]() Quote:
Actually it is, and today's OEMs do. Modern engines use much higher compression ratios, enabled by direct injection. The higher SCR increases efficiency even at part throttle, thus increasing fuel economy (in addition to increasing torque under wide open throttle). They can get away with these compression ratios due to the charge cooling as the fuel is injected directly into the combustion chamber (especially with multiple injection strategy at under medium loads and low-mid rpm). This then allows them to downsize the engine displacement (if desired) to further improve fuel economy. This is why OEMs use DI even on small economy cars, not just performance vehicles.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman Last edited by amcmike; 07-25-2022 at 06:30 PM. |
The Following User Says Thank You to amcmike For This Useful Post: | ||
