Old 07-28-2022, 08:57 AM
LKLusza's Avatar
LKLusza LKLusza is offline
Default Console shifter refurbishing
Hi All,
I recently had a 4L60E installed in my 1970 GTO and am now installing a Shiftworks detent kit in the console shifter. With more than 50 years of dust and gunk present, I'd like to do more than simply replace the detent plate. A secondary goal is to investigate the possibility of modifications to restore the "rally shift" functionality - not sure about that one yet, we'll see.
Anyway, if I give the mechanism a good cleaning, what type of grease / lubricant would anyone recommend when reassembling it? Thanks.
Larry
Old 07-28-2022, 10:37 AM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
Recently took mine apart, cleaned everything up, wire wheeled the shifter frame and reassembled with a small amount of white lithium grease. Super easy to do. Makes them like new!
Old 07-28-2022, 11:02 AM
LKLusza's Avatar
Thank you TxSportCoupe! I have a can of that on the shelf. And thanks for the pictures - they'll be a big help too.
Larry
The Following User Says Thank You to LKLusza For This Useful Post:
