Hop Stop Bars Issue
Hey anyone,
I have HO racing hop stop bars from 1994 in my GTO. The problem I’m now having is that the attaching point on the differential keeps coming loose on me.. The original attachment is one big square piece of metal washer where the bolt goes thru to center it. I have looked at The other hop stop bars and they have an actual metal bushing to help keep the bolt located in the differential. Has anyone been able to purchase just these metal bushings? The first pic is of with the HR racing bars look like with that square metal washer. The second pic is of the metal bushings I’m looking to find. Thanks, Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears Last edited by SD421; 07-28-2022 at 02:31 PM. Reason: Correct Spelling |
Hop stop bars issue
I had the identical set on my car for over 20 years, never had to tighten them! Center the raised portion in the bushing hole, use new lockwashers on top of the square piece and torque down.
The Following User Says Thank You to 67ramair4 For This Useful Post: | ||
Nylocs.
The Following User Says Thank You to Scarebird For This Useful Post: | ||
