#1141
I am almost done with the Dakota Digital gauges, will be done tomorrow about noon. I will post a video to YouTube. Preliminary testing shows these things are awesome
#1142
These are so amazing, sorry for the glare.
#1143
They look good
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#1144
If you are looking to upgrade your gauges these RTX by far are the coolest and best working I have ever seen
#1145
Those look great!
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#1146
Those look gorgeous! The dash really pops and looks so clean. I’m regretting my purchase of OPGI stock replacement rally gauge set already, haha
Sent from my iPhone using Tapatalk |
#1147
Seriously these gauges transformed the whole car it seems. SO many lighting options and performance counters.
#1148
Now that they’re installed are all readings what you expected? Engine temp, oil pressure, volts?
#1149
Yes same readings as the Stewart Warner
#1150
Figured out how to turn on the daytime backlighting
| The Following User Says Thank You to 64speed For This Useful Post: | ||
#1151
Those are impressive!
#1152
I am still getting a light scratch when power or high RPM shifting. I have a ton of adjustability in my clutch pedal. Should I be adjusting the clutch travel or the pedal stop?
#1153
I like those gauges. I had replaced my bulbs quite a while back ad was very disappointed the first time I drove it at night. The only gauges I could read were my aftermarket cluster and my hood tach that crapped out in about 2 years. My tach is now an ornament with moving parts that flatlines at 700 rpm.
Triple Black 1971 GTO |
#1154
I put the shortest belt I can possibly get on and it stopped squealing for a day. Any other suggestions, yes it has fluid in it
#1155
https://www.gates.com/us/en/power-tr...e-v-belts.html
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
| The Following User Says Thank You to TB1 For This Useful Post: | ||
#1156
I got seatbelts in the front as of today. Rear belts were supposed to be the 75 inch but they sent 60 inch. When I get the exchange I’ll install those
#1157
Just put 60” seat belts in my 64 yesterday. I can’t imagine why you would need them any longer.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
#1158
Where did you attach them
#1159
Here
| The Following User Says Thank You to Singleton For This Useful Post: | ||
#1160
"V Belt Supply". They have .500 wide and .410 in any length by 1/2" increments. I've used them for 10 years or so. No problems.
