Old 08-03-2022, 03:00 PM
Sport69 Sport69 is offline
Excellent.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
  #62
Old 08-03-2022, 07:16 PM
ALLTHINGSPONTIAC ALLTHINGSPONTIAC is offline
Originally Posted by Tim john View Post
*UPDATE*
First "prototype" emblem is in the books as of today. Pleased overall but work to be done to clean up the edges, crisp up the lines, tweak the nose a smidgen and try again...progress being made, all in the right direction. Stay tuned...
Tim
Great job!!
  #63
Old 08-14-2022, 11:57 AM
Tim john Tim john is offline
*UPDATE*
Made yet another trip down state to go over emblem progress, 3rd prototype has been produced, 3rd attempt photo attached. Fits the bumper profile beautiful top, bottom and both sides. Getting close to finalization. Real happy how this is coming together. I have fit #3 on three different factory 400 bumpers and each of them produced the same fit finish results, real pleased. Some liberties have been taken on the B side to help pilot the emblem. The bumpers clearance holes are very generous in size and the original emblem had plenty of real estate to move around so we revised the prototypes bosses to fit much better, and it does. In the attachment photo the emblem is just resting on the bumper, no fasteners are in place. The business that I am working with has been a real pleasure thus far, very passionate about what they do, pride and reputation comes to mind. Stay tuned.
Tim john---
  #64
Old 08-14-2022, 12:07 PM
65madgoat's Avatar
Love it. Appreciate your work on this.
Sell me the NOS emblem when you are done using it for this project
  #65
Old 08-14-2022, 12:46 PM
The NOS emblem used for reference on this project has failed miserably in the box, it has multiple cracks all over. For a new, never installed or exposed to the elements emblem it has failed miserably. The/this first generation Urethane or whatever they used back in 69 did not fare well over time but in GM's defense, it served its purpose, was never expected or intended to survive this long I am sure.
Tim
ID:	596387   Click image for larger version
ID:	596388   Click image for larger version
  #66
Old 08-14-2022, 01:01 PM
Looking good 👍
Old 08-14-2022, 05:44 PM
*UPDATE*
Tim john---
Amazing Job you are doing!
  #68
Old 08-14-2022, 07:25 PM
Thanks for the update Tim.
  #69
Old 08-17-2022, 11:49 AM
turbo69bird's Avatar
Awesome job ! So pleased to see this coming together.
Can’t say enough, how much I appreciate you putting the work into this project.
Such a great contribution to the preservation of 69 Pontiac firebirds, to get this correct. It’s quite often the first thing people will see
960 HP @ 11 psi, 9.70 at 146.
The Following 2 Users Say Thank You to turbo69bird For This Useful Post:
  #70
Old 08-22-2022, 06:15 PM
*UPDATE*
Well folks, Another trip down state last week but oh so worth it.
Today is a monumental day, the emblem is physically complete, the final version that is, and I am delighted to share with you the end results. The fit and finish is fantastic. The emblem is just resting naturally on the bumper, no fasteners installed in any of the pictures, the fit is that nice. Currently working on U.V. tolerant colors. The finish line is clearly on the horizon.
*As a side note; this reproduction fits much nicer than the NOS emblem used for partial reference..
Tim john---
ID:	597012   Click image for larger version
ID:	597013   Click image for larger version
ID:	597014   Click image for larger version
The Following User Says Thank You to Tim john For This Useful Post:
  #71
Old 08-22-2022, 07:50 PM
65madgoat's Avatar
Glorious!!! Thanks Tim John. Can't wait to be able to buy one (or two!)
  #72
Old 08-23-2022, 07:37 AM
Backside of bumper, emblem/bumper engagement. Note: emblem bosses have been enlarged to fit bumper clearance holes much better than OEM for improved self vertical positioning. The OEM emblem with it's smaller diameter bosses had/has a lot of real estate in the bumper for misalignment and movement even when snugged up.. Not a known problem but the potential is /was there.
Tim john---
ID:	597029   Click image for larger version
  #73
Old 08-23-2022, 07:38 AM
rwfisher's Avatar
rwfisher rwfisher is offline
Will you be testing how they hold up from cracking due to extremes of Heat / Cold?
  #74
Old 08-23-2022, 07:59 AM
Tensile Modulus (GPa) is 2.4
Tensile Stress at yield (MPa) is 40
Tensile Stress at break (MPa) is 37
Tensile Strain at break (%) is 25
Flexural Strength (MPa) is 71
Heat Deflection Temp (Degree C) is 145
I have had the emblem installed on an OEM front bumper for several days up against the house vinyl siding in the sun where the heat is the most intense that I have for multiple hour testing for signs of failure and warpage, I have not experienced either. I also have a heat gun and laser temp gun for temperature confirmation as well if the clouds roll in. I currently have another emblem in our chest freezer, all is well thus far.
The resin has very good chemical resistivity and high heat tolerance which also provides very good surface finish.
Tim john---
  #75
Old 08-23-2022, 08:05 AM
rwfisher's Avatar
Living in Vermont, I’m interested in the freezer experiment!!😂
Tensile stress at break (MPa) is 37
Tim john---
  #76
Old 08-23-2022, 08:30 AM
Michigan experiences plenty of Sub Zero weather as well. I am in Michigan.
Tj-
  #77
Old 08-23-2022, 10:00 AM
ramairhart ramairhart is offline
Default 1969 Firebird 400 Emblem
Outstanding work. Really appreciate your time and effort to bring this emblem to birth.
Thanks so much
Hart
“A veteran - wether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the (‘United States of America’, for an amount of ‘ up to and including their life.’” Unknown
  #78
Old 08-23-2022, 08:51 PM
necdb3's Avatar
necdb3 necdb3 is offline
Great news
  #79
Old 08-24-2022, 11:11 AM
Looks fantastic so far!
Thank you very much for the hard work a true service to the Pontiac community.
Low production one year only and done for the love of Pontiacs..
very cool.
  #80
Old 08-28-2022, 04:59 PM
jabgolfcars jabgolfcars is offline
Outstanding! Count me in for one.
