#1201
#1202
What was your oil pressure prior to this issue?
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#1203
That’s not who I used. Wayne Sless built my engine
#1204
I was going by this post, which is titled 'Carolina Machine Engines', and you started the thread:
https://forums.maxperformanceinc.com...d.php?t=819219 .
#1205
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Royal Pontiac (Dealer# 07-679) 70 Formula 400/auto |
#1206
Wayne has a sterling reputation with Pontiacs. If I had to hazard a guess I would say one of my “noisy” Lunati lifters let go. I had a pretty good ticker. If I can I will use the cam and a better set of lifters. There was no terrible crunches or anything like that so I am just praying.
#1207
Regardless of what’s salvageable I will not be using those lifters. I always had a weird feeling about them when handling them. I felt like they should be more “robust” in a word but then I thought if it’s a Lunati cam why not lifters. Then I had the ticker and was frustrated but then I saw the post wanting noisy lunati lifters so I felt better. Since I will be replacing the lifters regardless what is the quietest and I hate saying best but what should I buy?
#1208
Jones from Jones cam told me he would run Johnsons.FWIW,Tom
#1209
If the pushrods simply came out, your rocker arms were misadjusted (loose) and turned or rocked enough to allow the pushrods to slip out. That ticking you heard may have been loose rockers. If the pushrods are bent, then you had mechanical interference at play. Valves may have bounced and kissed the piston top or your rocker ratio and pushrod pocket offset may have caused your retainer to hit the guides. Things like valve spring coil bind need to be rechecked and ruled out but typically, you will also have a broken valve spring from coil bind.
Triple Black 1971 GTO |
#1210
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
#1211
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#1212
If it does not need any machining I am rebuilding it myself because if what me and Wayne speculate is true the lifter jumped the bore. NO one has any Pontiac cam blanks but Isky said they repair cams no matter how bad. If that’s what happened that’s the route I will take. I know I’m gonna catch hell for this but I have built 8 SBC and put cam and lifters in a 389 before. If I don’t have to do anymore disassembly than I hope then I feel confident I can do it.
#1213
I overreved many times but that was with a HFT. Years in fact. MSD has a nifty ignition module with a build in rev limiter that will save you many future problems. Myself, I knew eventually there would be trouble back then but $100 bought a lot of beer. |
#1214
Its not his fault that there was a possible parts failure. I am not rebuilding anything per se. I will take it out, take the pan and lifter valley off, assess damage and do what is needed but if possible I am gonna avoid taking the heads off etc.
#1215
Why not just pull the intake and valley pan and KNOW if it has to come out first!Tom
#1216
Agreed. It could be as simple as replacing a roller lifter set and/or push rods from misadjustment. Hopefully no valve damage.
#1217
Well I am going to do that this weekend but I still have to take it out to get the trash out of the pan
#1218
Are you keeping the BB Chevy rocker arms on there?
#1219
Trash from what? Oil filter? I must have missed something .
#1220
How can you know there is trash in the pan?Tom
