Old 08-23-2022, 11:21 AM
Wow, more than a few left crappy reviews:
https://www.google.com/search?q=caro...lient=gws-wiz#
  #1202
Old 08-23-2022, 11:31 AM
grivera's Avatar
grivera grivera is offline
Originally Posted by 64speed View Post
It holds 10 pounds at idle even coasting down the road...
What was your oil pressure prior to this issue?
Will Rivera
  #1203
Old 08-23-2022, 12:23 PM
64speed's Avatar
64speed 64speed is offline
That’s not who I used. Wayne Sless built my engine
  #1204
Old 08-23-2022, 01:06 PM
I was going by this post, which is titled 'Carolina Machine Engines', and you started the thread:
https://forums.maxperformanceinc.com...d.php?t=819219
  #1205
Old 08-23-2022, 01:14 PM
Singleton Singleton is online now
Pretty obvious from that first post of the thread that 64speed was asking opinions of using Wayne Sless OR Carolina Machine
Sold new at Royal Pontiac (Dealer# 07-679)
70 Formula 400/auto
  #1206
Old 08-23-2022, 04:09 PM
64speed's Avatar
Wayne has a sterling reputation with Pontiacs. If I had to hazard a guess I would say one of my “noisy” Lunati lifters let go. I had a pretty good ticker. If I can I will use the cam and a better set of lifters. There was no terrible crunches or anything like that so I am just praying.
  #1207
Old 08-23-2022, 04:45 PM
64speed's Avatar
Regardless of what’s salvageable I will not be using those lifters. I always had a weird feeling about them when handling them. I felt like they should be more “robust” in a word but then I thought if it’s a Lunati cam why not lifters. Then I had the ticker and was frustrated but then I saw the post wanting noisy lunati lifters so I felt better. Since I will be replacing the lifters regardless what is the quietest and I hate saying best but what should I buy?
  #1208
Old 08-23-2022, 04:58 PM
tom s tom s is offline
Jones from Jones cam told me he would run Johnsons.FWIW,Tom
  #1209
Old 08-24-2022, 11:55 AM
NeighborsComplaint's Avatar
Well I’m getting 16 pushrods cause I don’t want to replace just two. Just wondering
Wait and see what your builder finds.
If the pushrods simply came out, your rocker arms were misadjusted (loose) and turned or rocked enough to allow the pushrods to slip out. That ticking you heard may have been loose rockers.
If the pushrods are bent, then you had mechanical interference at play. Valves may have bounced and kissed the piston top or your rocker ratio and pushrod pocket offset may have caused your retainer to hit the guides. Things like valve spring coil bind need to be rechecked and ruled out but typically, you will also have a broken valve spring from coil bind.
Triple Black 1971 GTO
  #1210
Old 08-24-2022, 12:59 PM
Best pushrods.
https://mantonpushrods.com
  #1211
Old 08-24-2022, 02:18 PM
ZeGermanHam's Avatar
+1 to this.
1998 BMW 328is (track rat)
  #1212
Old 08-24-2022, 04:42 PM
64speed's Avatar
If it does not need any machining I am rebuilding it myself because if what me and Wayne speculate is true the lifter jumped the bore. NO one has any Pontiac cam blanks but Isky said they repair cams no matter how bad. If that’s what happened that’s the route I will take. I know I’m gonna catch hell for this but I have built 8 SBC and put cam and lifters in a 389 before. If I don’t have to do anymore disassembly than I hope then I feel confident I can do it.
  #1213
Old 08-24-2022, 04:54 PM
P@blo's Avatar
P@blo P@blo is online now
What are you going to rebuild? You paid a guy a lot of money to build your motor and if it were me I would be going back to him.
I overreved many times but that was with a HFT. Years in fact. MSD has a nifty ignition module with a build in rev limiter that will save you many future problems. Myself, I knew eventually there would be trouble back then but $100 bought a lot of beer.
  #1214
Old 08-24-2022, 05:19 PM
64speed's Avatar
Its not his fault that there was a possible parts failure. I am not rebuilding anything per se. I will take it out, take the pan and lifter valley off, assess damage and do what is needed but if possible I am gonna avoid taking the heads off etc.
  #1215
Old 08-24-2022, 05:58 PM
Why not just pull the intake and valley pan and KNOW if it has to come out first!Tom
  #1216
Old 08-24-2022, 06:53 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Agreed. It could be as simple as replacing a roller lifter set and/or push rods from misadjustment. Hopefully no valve damage.
  #1217
Old 08-24-2022, 07:20 PM
64speed's Avatar
Well I am going to do that this weekend but I still have to take it out to get the trash out of the pan
  #1218
Old 08-24-2022, 08:09 PM
grivera's Avatar
Are you keeping the BB Chevy rocker arms on there?
Will Rivera
  #1219
Old 08-24-2022, 09:57 PM
68WarDog's Avatar
Trash from what? Oil filter? I must have missed something ��.
  #1220
Old 08-24-2022, 10:02 PM
How can you know there is trash in the pan?Tom
