Check out the entire list.
PLEASE communicate thru this thread OR text (908.208.7778) to make sending pictures easy. Just ask for pictures! PLEASE USE THE ITEM NUMBER IN THE AD! 1. (3) 1958 NORS Pontiac Tail light lense. 2 have the NORS trim ring.* Glo-rite $50 for all 3. 2. SOLD 3. 1966 (65?) Full Size (except GP) Vent window reveal molding passenger side ... nice condition $20 4.* 1951-52 Pontiac NOS gauges.* 2 water temp and one alternator ... $30 for all 3.* Use for your hot rod! 5. 1965-68 full size Auto Shifter gate slide.* $10 6. 1970-1972 GTO NOS Coat hooks $15 7. SOLD 8. 1968-1971 GTO horn relay cover.* Original.* $25 each both for $40 9. NOS Pontiac 63-74 condenser and rotor $12 10. 1966 Full Size NOS Pontiac Stop Package front wheel (2) $15 each or $25 for both 11. Pontiac Seat tracks. I have looked for pictures and have felt comfortable in stating which years/models they are for.* a. 1966-1972 GTO pair drivers side. Repops are $90+ ... these are $45 b. 1966-1972 GTO pair passenger side $20 c. 1971-1981 FB, Camaro one driver and one passenger adjust lever tracks* $50 d. 1966-1972 GTO 2 tracks, both driver adjuster. $30/ea or $45 for both e. 1967-1969 FB, Camaro 2 tracks each are passenger adjuster. $25/ea or $35 for both f. 1967-1969 FB, Camaro driver adjuster track. $35 g. 1 passenger adjuster lever track with busted ten but comes with a sepetate mint base with perfect tabs. $35 h. some misc track parts. $20 12. SOLD 13. Gas tank ... I'm told 1967/68 full size ...* you determine!* Comes with sending unit.* $50 14. 2 Rally Wheels 15×6. 5×5"* KY code 1971.** $150/pr 15. 2 Rally Wheels 15x7 5x4.75" $150/pr 16. 1 Rally Wheel 15x6 5x4.75"* $75 17. 4 Rally Wheels JT* (2)12/5/69* (1) 1/13/70. (1) 2/20/70. 5x4.75" blasted and primed. $350 for matching date pair* $150 each for the other 2 18. Pontiac hub caps 14" buy all 11 for $75 19. 1970 GTO Convertible glass ... left and right door and rear top.* Factory original tinted glass.* $400 20. 1970 GTO Choke Thermostat all ex. RA4* 7040097* this is the correct 1970 GTO 4bbl and RA3 part number* $150 21. Pontiac original v8 engine lift hook. Shaped different than repops.* $10 22. Pontiac original speaker.* Needs restored. Part #7300614* 1966-1972. $20 23. Pontiac 1969-1972 Gas Pedal. New Year One repop.* $26 in Year One cataloge.* $20 here. 24. 1969-1972 GTO a/c duct, LH Outer, part #9782386.* $50 25. EIS remanufactured brake shoes 1968-72 GTO and other models* $30 26. 1971 GTO, 70-71 Firebird w/w fluid jar, part # 3961557.* With attaching bracket. Great condition.* $45 27. 1970 Ram Air 3 exhaust shroud.* Original and fast superior shape and fit to repop. Great condition.* $600 on ebay $300 here! 28. 1970-1972 GTO/GP Part #546427 and 1970 GTO/GP Part #486011 upper panel center.* Excellent shape.* $25 each 29. 1970-1972 GTO left/right upper Cowl grills. Original $50 30. 1969-1972 GTO Ashtray and bracket.* Original and MINT. No fit/ finish issues.* Use for show car.* $95 31. 1970 GTO Clock Delete. Original.* Great shape with attaching screws.* $35 ea.* (I have 2) 32. 2 used Pontiac Neutral Safety/backup switches.* For Automatic transmissions. See pics for condition.* Part #1993448 and #1994153. $15 each 33. 1970 GTO dash a/c deflectors.* Original and MINT.* I would say NOS but don't have the boxes.* For show cars.* $180 34. 1970 GTO all original and mint. Cigarette Lighter with 2 recepticles and 1 bezel and 1 heating element ($50 )***** Light Switch* pull knob with bezel** Light Switch (SOLD).* Windshield Wiper Switch (SOLD) 35. SOLD 36. 1970-1972 GTO tail light housings excellent.* Ebay just sold a pair for $129 plus $30 shipping!* I say $100. 37. 1970 GTO tail light lense LH.* Great condition.* No cracks in the lense.* $100 38. SOLD 39. SOLD 40. 1970-1971 Pontiac GTO, GP* NOS rear seals* (2)* $15 each or $20 for the pair. 41. 1969-1972 Pontiac ignition Switch.* Used original.* Look very clean. Have 2.* $20 each or $30 for both. 42. 1970-1972 GTO wiper switches.* Used. $25 each.* $60 for all 3. 43. 1965-1966 GTO heater adjuster lever/knob. $20 44. SOLD 45. I think this is 1970 GTO backup lamp harness with bulb.* You determine.* $15 46. 1970 GTO grill chrome surrounds L/R. $150 47. Pontiac NOS upper beam headlamp.* $10 48. SOLD 49. SOLD 50. 1970 GTO wiper arms original Trico.* $50 51. 1965 Pontiac, Chevy, Olds, Buick, Caddy New Convertible Pillar Post weatherstrips. $50 52. 1969-1972 GTO outside mirror.* Looks NOS. MINT.* $75 53. 1969-1970 GTO 4 speed neutral safety switch.* $30 54. 1970 GTO wiper arms original TRICO $50 55. SOLD 56. 1968-1972 GTO License Lamp. Original lense with great silver paint.* Complete assembly with harness and blocking plug.* $30 57. Valve Stems with caps ... new.* $5 58. 1970 GTO Ram Air exhaust tubing.* NEW. Original style.** $45 59. 1966-1967 NOS Pontiac b-up switch (clutch safety switch) mounting bracket.* $45 60. SOLD 61. 1970-1974 GTO NOS radio interference shield.* $40 62. Carter 4bbl Choke pull off. New.* $15 63. 1968-1972 GTO original license lamp lens.* Excellent with silver paint intact.* Close to NOS.* $45 64. EIS drum brake springs.* New. $10 65. 1970 GTO grill emblem.* Used.* $25 66. SOLD 67. Pontiac battery hold down?* Not sure of year/model?* $10 68. SOLD 69. 1968-1975 NOS Pontiac Circuit Breaker $20 70. Pontiac NOS glove box cylinder $40 71. Pontiac NOS 1969-1975 case and rotor glove box lock $20 72. SOLD 73. Pontiac GTO 1968-1972 NEW Repop inside door handles 1 pair mint condition $45 74. 1968-1972 Kick Panels Blue L/R used in great condition.* I would re-dye.* I can do them for an additional charge.* I believe these are for a/c cars.** $90 75. 1968-1972 GTO rear floor mats.* New.* Either nos or repop.* I've had them for 20 years.*** $100 76. 1970-1972 GTO NOS Convertible top switch.* Mint!* The lettering is different font thickness than repops.* For show cars where originality matters.* $300 77. 1969-1970 GTO ashtray fiber optic harness and bulb. $35 78. 1970-1972 GTO w/ac NOS blower switch #7311845* $50 79. 1970-1972 GTO NOS w/w switch.* Repops are $100.** $200 80. 1967-1975 Pontiac NOS power trunk button mounted in glove box.* Pontiac used green originally.* Repops are yellow.* $125 81. 1968-1972 GTO NOS Parking Brake release handles.* Lettering different than repops* 1 left $25 82. 1968-1972 GTO rear view mirror 12" in excellent condition including the glass and stainless.* Day/Night adjustment.* Original GM not a repop.* $20 83. 1969-1971 Pontiac 1968 Firebird NOS headlight switch #1995154 mint.* Not a cheap parts store item but original GM.* $65 84. 1968-1977 Firebird 1969-1972 GTO/GP NOS headlight switch #1995199 which superceded the original #1995154. Mint.* Not a cheap parts store item but original GM.* $65 85. 1968-1970 Pontiac NOS Seat Adjuster Knob.* Mint!* When only original GM will do.* $50 86. 1969-1972 GTO/GP NOS switch and harness for glove box light.* MINT $50 87. 1967-1972 Pontiac dash knob/bezel aset.* Repop.* New.* Mint.* $25 88. 1970-1972 GTO* W/W Switch, including a mint original mount. Used. Original GM.* Just clean.* Looks very good.* $75 89. 1968-1972 GTO Convertible latch assemblies.* L/R.* Restored.* $100 ea or $150 for the pair. 90. 1968-1977 Firebird 1969-1972 GTO/GP headlight switch #1995199 which superceded the original #1995154. In an NOS box but looks dirty etc. Not a cheap parts store item but original GM.* $40 91. Trim for sale A. 1966/67? GTO w/s bottom right driver outer $25 B. 1966/67? Qtr Panel retainer (22) $20 C. 1967 GTO Upper eyebrow front grill* (pair)* $75 D. 1966/67 GTO Qtr Reveal (LH) (4) $25 E. 1966/67 GTO Qtr Reveal (RH) (2) $25 F. 1966/67 GTO Drip Mldg A-Pillar (5) $20 G. 1966/67 GTO w/s (RH) $25 H. 1965/64 GTO Door Edge Guard (LH?) $50 I. 1966/67 GTO Dash grab bar bezel (3) $20 J. 1968 GTO Qtr Panel Interor $10 K. 1967 GTO Door Edge Guards 1 SOLD (3 sets left) $95 1966 GTO Door Edge Guard $95 L. 1966/67 GTO door post weatherstrip retainer L/R* $50/pr. (12) M. 1966/67 Tempest/Lemans Rear outer qtr belt mldg. I have 2 both look like driver side?* $10 each O. 1967 Bonneville Qtr Rocker Moldings L/R 34.5" top measurement. $100 P. Misc Moldings not sure of app ... $10 each ... I have 8 different pieces. Q. 1965 Full Size? Bucket Seat Chrome Trim.* 11 pieces.* I believe 1965 full size but you check them out and determine.* $100 for all 11 pieces.* 92. Exhaust tips brand new never installed 2.5" opening* $25 93. 1967 GTO dash grab bar handle.* Good used condition $40 94. 1965 GTO dsah lucite plaque nameplate $50 95. 1967 Lemans dash lucite nameplate $20 96. 1966 GTO Dash Lucite nameplate $80 97. 1966/67 GTO Heater Control Cable $10 98. ???? Door Edge guards.* Not sure of model/yr but my guess is 1968 and later because of no screw in tabs.* Chrome moldings.* $35 99. 1993-2002 GM NOS Auto Trans Vent Tube. $5 each* $15 for all 4 100. 1969-1970 GTO remote mirror bezel with bracket.* Excellent.* Can be put on a show car IMO.* $50 101. 1971-1972 GTO Water Neck $30 102. 1967-1968 FB, 1968 GTO,1969-1972 Pontiac NOS Turn Signal Lever w/out CC $45 103. 1970-1972 GTO, Lemans Dash Bezel with a/c. Has air deflector. Also has spot for either Convertible Top or Rear Defroster switches. Excellent Condition. Look at the silver. Look at the back and the mint mounting tabs.* Could be used for a local show car IMO.* $350 104. 1969 Pontiac Judge NOS Decals $50 each 105. 1971-1972 GTO NOS Side Marker Lens LH. Ebay is $450.* I'm at $300. 106. 1969-1970 Trans Am, 1971-1972 GTO/FB,GP, 1973-1971 FB NOS Horn Extension. $45 107. 1964-1966 GTO Steering Column Floor Carpet Guard NEW Repop.* $45 (2) 108. 1965 Pontiac Bonneville NOS molding Fender to rocker panel cover $50 109. 1989-1990 Firebird NOS air deflector RH. $20 110. 1968-1972 GTO Arm rest pads.* One driver only.* One in excellent condition.* $15 111. 1970-1971 Firebird, 1971 GTO/FB* fluid jar, original nor repop., just clean and it'll be amazing.** $40 112. 1969-1972 GTO Horn Relay cover.* Just clean and paint.* It'll be a show piece.* $15 113. 1971-1972 GTO, 1973-1974 TA SD* Fuel Vapor Cannister WITH mounting bracket!** Looks excellent.* $45 114. 1970 GTO headlamp bezels.* L/R outer.* Has some pitting.* Driver quality. Polish for local show.** $45 115. 1970 GTO Headlamp bezels. L/R inner. Some pitting.* Driver quality.* Polish for local show.* $45 116. 1970-1972 GTO A/C control head.* Comes with mounting bracket, control cable and intact wiring harness.* $100 117. 1966-1972 Pontiac Radiator Cap. USED!* Restore and use.* $10 118. 1970-1972 GTO Wiper switche ground mounting plate.* Mint.* $15 each $20 for both. 119.* Hood Latch Springs. $15 for the pair. *************************************** 120. 1966 Grand Prix Parking lamp assemblies.* L/R. No lenses.* The cups have light pitting.* The bezels are excellent.* The harnesses look too be excellent.* The inside cup and gaskets are there.** $75 121. 1966 Full Size Dash Clock.* Not Tested ... as is ... $20.* Tested, Cleaned, Guaranteed working $125. 122. 1965 Pontiac NOS Moraine PB repair kit $40 123. 1966-1972 Pontiac Radiator Cap.* Box marked NOS but I'm not sure by looking at the back.* In great shape however.* Nothing worse then seeing the wrong radiator cap on a classic Pontiac.* $95 124. 1965 Full Size headlamp bezel specialty screws and washers. 8 per set.* Limited quantities ... $25 / set 125. 1965-1966 Pontiac Full Size. Interior door handles.* 3 driver, 2 passenger driver quality.* $20 for all 5. 126. 1969-1970 NOS remote mirror bezel.* Mint.* Show car worthy.* $250 127.* 1965-1966 Pontiac Full Size set of used original window cranks. Nice driver condition.** $20 for the set. 128. A-Body Rear Qtr Armrests a. 1968-1972 a-body rear qtr arm rests with one ash tray ... black plastic with no vinyl cover ... some damage to one and the other is pretty good.* $20 for the pair b. 1968-1972 a-body rear qtr arm rests metal with green vinyl covering.* Includes ash trays.* Good driver condition, re-dye for show.* $60 for the pair. c. 1968-1972 a-body rear qtr arm rests with ash trays.* Plastic with black vinyl covering.* Need to be recovered.* $40 for the pair. 129. A-Body Kick Panels a. 1968-1972 a-body kick panels.* Green.* Have pull cable adjustable vents.* One side missing the cable and the grate/vent but has the flap. The other side has the cable, flap, and grate/vent.* $50 for the pair. b. 1964-1966 GTO passenger side Kick panel with grate/vent.* Needs clean and dye.* $20 c. 1968-1972 GTO Kick Panels for a/c car.* Just re-dye to taste.* $50 for the pair. d. 1968-1972 GTO Kick panel.* Driver's side only. Black.* $25 e. Various Kick panel gates/vents. $10 each 130. 1968-1972 door Armrests with pads. Black.* Can be used on a driver right now.* Restore for show.* $30 for the pair. 131. 1967-1970 Pontiac aluminum alternator bracket. #9786903 Just clean.* In good condition.* $40 132.* Unknown year/ model heater control.* Has buttons, lever, and round spinning dial for high-low fan. Use for parts.* Hate to throw things away.* $10. 133. 1968-1972 GTO Bucket seat lower trim panel/covers.* Sold in pairs unless otherwise stated. Most, if not all, will need clean, prime, and re-dye to the color of your choice.* Some will work for local show car, others for drivers (scratches etc.).* None are damaged, cracked, or chipped. a. 1 pr gold with power seat openings.* Decent but scratches etc. $40 b. 1 drivers side only with power seat openings.* Can take a passenger side from another pair if needed.* $25 c. 2 pair that are covered in vinyl ... looks factory.* $25/pr d. 3 pair that are metal ... excellent condition $75/pr e. 9 pair, plastic, in very good condition $40/pr f. 13 pair, plastic, with multiple imperfections only $20/pr 134. 1965 Full Size? Bucket Seat Chrome Trim.* 11 pieces.* I believe 1965 full size but you check them out and determine.* $100 for all 11 pieces.* 135. 1968-1972 GTO, 1968-1969 Catalina, 1969-1970 Grand Prix (2) EIS SP414 brake hoses new. $15 for the pair 136. 1970 GTO 455 motor mount used $10 137. 1968-1972 GTO Convertible sunvisor brackets NEW Repop.* Comes with visor hold down inserts $60 138. Rearview Mirror bracket.* New Repop from Summit. Don't know application.* $25 139. 1968-1970 GTO Convertible rear qtr ashtray tops.* These are the ribbed originals.** Triple plated restored. Have 2 sets.* $150/set 140. 1968-1970 GTO hardtop rear qtr ashtray tops. These are rubbed originals.* Triple plate restored.* $150 141. 1968-1972 GTO Convertible knuckle latch receiver.* Original.* Triple plate restored. 2 sets $100/set 142. 1968-1972 Convertible Sunvisor brackets.* Original.* Triple plate restored.* Have 2 pair.* $150/pair 143. 1969-1972 Remote drivers mirror bezel.* Original.* Triple plate restored.* $125 144. 1968-1972 Convertible rearview Mirror bracket.* Original.* Triple plate restored.* $125 145. 1968-1972 rear qtr ashtray receptacles.* Have 2 Convertible and 3 hardtop.* All original.* All triple plate restored.* Each has little holes in the bottom from the blasting before triple plating. Can be restored.* $20 each. 146. 1965-1970? Pontiac Hardtop Sunvisors with brackets.* Used.* Driver condition at best.* $10
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather Last edited by 70ra455; 09-09-2022 at 12:32 AM. |
pics of 103 and 33 text 7342160761 thanks
72 Luxury Lemans nicely optioned ![]() |
Can I get a picture of the exhaust tips # 92??
Black70GTO here are the pics ...
1970 GTO Convertible 455 Ram Air M-21, Atoll/Blue/Black, Hood Tach, 3:31 12-Bolt Posi, A/C, Console 1966 Grand Prix 421 Tripower 4spd, Marina Turquoise/Turquoise, a/c, console, posi, reverb. pa, pb, ps, remote mirror, mats 2010 Dodge Challenger R/T Classic, 6spd Hemi, Detonator Yellow, black stripe, black leather |
Tim66
Check your private messages ... "Name and Shipping Address and phone number and I'll get a shipping quote"
Hi 70ra455,I cannot find anything
Please read the message above that you responded to. I need your NAME, ADDRESS, PHONE NUMBER so I can get you a shipping quote for the item
Ok I found it in the PM ... no need to respond. I'll get u a shipping quote
