Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 09-19-2022, 12:21 PM
BILL BOWMAN1's Avatar
Default WTB Holley red pump
Looking for a good Holley red street electric fuel pump.
Old 09-19-2022, 05:12 PM
misterp266's Avatar
I have a NIB blue pump if you’re interested. 110GPH. LMK
" Darksiders Rule "
Old 09-19-2022, 07:40 PM
Thanks for the offer but no.
Old 09-19-2022, 10:56 PM
73 TRANSAM 73 TRANSAM is offline
I have a Mallory 140 pump
Old 09-20-2022, 08:02 AM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
Probably been mentioned 1000x but in case, During my restomod,put in brand new Holley pump. Ran some quick pressure/leak tests on the unfinished chassis. Fast forward 1 season where I installed the engine and tried once again to test for pressure/leaks. Nothing!
Autopsy of pump showed impeller completed rusted solid. Take away? Don’t put anything not alcohol compatible on a vehicle unless your running rec gas 100% of the time. How hard could it be for them to just harden the impeller??? Cheap ass crap vs ethanol…..
My story, your mileage may vary
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 09-20-2022, 08:45 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Bill, I have a slightly used Holley Black pump if you're interested
Chris D
Old 09-20-2022, 09:28 AM
Thanks, just a street cruiser and tying to not run a regulator.
Old 09-20-2022, 03:17 PM
Old Goat Racer's Avatar
Price ?
Everybody knows somthin.
Nobody knows everything !
Old 09-21-2022, 10:14 AM
I will look.
Old 09-22-2022, 12:03 PM
I have a slightly used RED Holley Fuel Pump with a By-Pass Circuit added to the pump
if you want just the red pump. PM me and we can work out a price & shipping info.
Old 09-22-2022, 08:19 PM
PM sent Tom
