Old 10-06-2022, 07:25 PM
lucky1 lucky1 is offline
Default Seating front oil seal.
What would you use to seat (tap in) the front oil seal with in car timing cover ?
Thank you.
Old 10-06-2022, 08:00 PM
mgarblik mgarblik is offline
If still installed on the car, I use a 3/4" drive, deep wall socket. A cheaper alternative might be a length of the correct size PVC pipe.
Old 10-06-2022, 09:22 PM
grivera's Avatar
grivera grivera is offline
I’ve used a threaded cast iron pipe that fits over crank snout, with flange on one end
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
The Following 2 Users Say Thank You to grivera For This Useful Post:
