Old 10-09-2022, 12:44 PM
Burn it one of your dailys.
Maybe pour in a quart through a filtered funnel right after you fill up the tank.
Easy and legal.
This^
Dilution is the solution
Old 10-09-2022, 01:55 PM
An old friend of mine had me pump out a few gallons of stale gas that was likely just a few years old out of the tank of his VW bus. It didn’t run worth a damn with the old gas and he needed it to run good enough to load onto a transporter since he was selling it.
I took the stale gas home with me and I ended up burning it in my 2 daily driver Hondas. I poured in about a gallon into the 13 gallon tank so it was about 12 gallons of new gas to one gallon of stale gas.
No problems and the way it drove didn’t change.
All good, with the price of gas nowadays I’d definitely run it in one of your cars little by little.
Here’s the 1962 Deluxe Samba (sold for 160K) pictured with my 1966 single cab pickup. My friend restored both of them.
Old 10-09-2022, 06:59 PM
Sirrotica's Avatar
If the gas is really stale, say 2-3 years old, it's not any more volatile than kerosene is. My emergency genset has sat for roughly 2 years with the same fuel in it. I tried starting it late last winter as there was an ice storm forecast the next day, and no start. I had some real gasoline in a can and poured a little into the carb throat, and it started. It would run once you started it on fresh gas, but it was never going to start with the stale gas.
Just out of curiosity I drained a little of the stale gas and tried to light it with a propane torch in the driveway. I had a hell off a time even getting it to light with the torch, just about like K1, or diesel lights. So yes diluting it in another car is probably going to be the easiest way to get rid of it.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 10-09-2022, 09:02 PM
AG's Avatar
AG AG is offline
Wow. I responded to Shiney's post not yours. You obviously don't know what a greenhouse gas is but I won't waste my time explaining.
Old 10-09-2022, 09:11 PM
Schurkey Schurkey is offline
PLEASE DO. I'd love to know how I'm wrong about water vapor and methane being more-effective greenhouse gasses than CO2.
Old 10-10-2022, 09:41 AM
Shiny Shiny is offline
Thank you all. I understand the different enviro impacts for evaporation and combustion.
The combustion impact is probably not much different if I burn it in a vehicle or on a brush pile, although there's no catalytic converter on my brush pile!
Others have pointed out evap is illegal and burning in a vehicle is not. This is a good point, regardless of which impact is "worse".
I didn't want to start a battle on the politics nor the science of global warming impact. I just wanted to know if the lack of a hazardous waste disposal process for gasoline was unique to my county. Seems not.
Old 10-10-2022, 12:00 PM
Cliff R's Avatar
Cliff R Cliff R is offline
I do the plastic gallon milk jug into the burn barrel, then run as FAST as I can.
Years ago I made the mistake of mixing it with used lube oil and dumped it in the burn barrel and didn't run for my life. I was nicely remarded with about a 3 second delay...then KA-BOOM! Singed a good bit of hair off my arms and even got some of my eyebrows.........a STOOPID move I plan NEVER to repeat........
Old 10-10-2022, 03:29 PM
Lee's Avatar
Lee Lee is offline
My dad poured some old gasoline on a bush he wanted to kill. It was next to a chain-link fence. The best he can figure is the bush rubbing on the fence created some sort of static charge, as the gasoline ignited as he was pouring it! That scared the p!$$ out of him.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 10-10-2022, 04:51 PM
Cliff since the plastic jug melts slowly it does not seem to flair that high-actually surprised me how little it was, even filling a plastic 2 gal cat Litter jug. But I keep themsmall so I can toss them from a distance!
Old 10-10-2022, 04:58 PM
I am fortunate in that with-in a mile of my current home, I have a Lawn Mower Shop that will take stale gas and dispose of it safely.
I have been taking stale gas there for many years.
Look into that option, it is a lot safer.
A friend was burned over 90% of his body, DIED, due to messing with stale gasoline.
I have posted about that sad deal in the past.
The Following 2 Users Say Thank You to Tom Vaught For This Useful Post:
Old 10-13-2022, 09:49 PM
CDub76's Avatar
CDub76 CDub76 is offline
I live in the Boston, MA area. My community has household hazardous waste disposal twice per year. They take all sorts of nasties including fluorescent bulbs and antifreeze.
The Following User Says Thank You to CDub76 For This Useful Post:
Old 10-14-2022, 09:39 AM
My county has a haz mat disposal way across from me and on gas maybe takes 5gal at a time.
Old 10-14-2022, 11:27 PM
redbird68's Avatar
redbird68 redbird68 is offline
If it is halfway decent i will dump waste gas into a daily driver
If it is beyond use i use it for weedkiller
When i was a kid we had a spray bar hooked to a truck we used to spray our gravel roads with diesel, worked great to stop dust/weeds whatever
birds, goats and a few outliers
The Following User Says Thank You to redbird68 For This Useful Post:
Old 10-15-2022, 03:58 PM
My hometown used to spray the dirt alleys to keep the dust under control.
I suspect that was how they got rid of all the waste oil from the various city fleet vehicles, mixed with enough diesel to do the entire city.
They haven't done that for decades.
