Closed Thread
Old 10-11-2022, 06:37 AM
Originally Posted by JSchmitz View Post
I fill my filters. The chances of bearing damage, from momentary oil starvation, are much higher than from contamination in new oil. That's where I'm "placing my chips".
How does everyone feel about blocking the oil filter bypass valve? LOL!
In some applications the mod has benefits, perhaps one being racing as
the HO Guys recommended that mod years ago.
That being said the bypass is there for a couple of reasons:
Filter plugged or very cold start-up conditions where the oil needs a path
to the oil galleries vs shearing the oil pump shaft.
That is why the OEMs test at -40 degrees F in Canada.
  #42
Old 10-11-2022, 07:11 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
The Following 2 Users Say Thank You to JSchmitz For This Useful Post:
  #43
Old 10-11-2022, 08:16 AM
After reading a bunch of oil threads in here I've come to this conclusion.
1) No one here is interested in adding a by-pass filter.
2) No one even cares enough to run an oil analysis to see if the oil is even doing the job they think it is.
3) This tells me that most here aren't the least bit worried about the slight possibility that they may introduce a microscopic piece of dirt while pre filling their oil filter.
I seriously doubt something like that is going to warrant a complete overhaul in our lifetimes. Most of us will be dead and gone before then.
I think when you reach a certain age, you have to pick and choose your battles. Most of us have other things to worry about.
Interesting discussion though.
https://youtu.be/XqEydRRRwqE
The Following 6 Users Say Thank You to Formulajones For This Useful Post:
  #44
Old 10-11-2022, 08:30 AM
mgarblik mgarblik is offline
Never going to get a consensus on this one. Just like, "Which brand of oil is best" I can say with confidence the following: 1. most new cars do not have an oil filter you can pre-fill because they are mounted in a way that you just can't do it. Most new cars have canister type filters, not spin on type. Can't pre-fill them. 2. new oil sold in bulk and distributed through a buildings plumbing system has a greater opportunity for dirt to be in the delivery system. 3. New oil is not as "clean" as you might like to think. 4. Never understood what exactly pre-filling was supposed to do?
The Following 4 Users Say Thank You to mgarblik For This Useful Post:
  #45
Old 10-11-2022, 08:34 AM
Really?? New cars have now went back to the old canister filters like we had in the 50's and 60's?? Wow that seems like a step back. Interesting.
  #46
Old 10-11-2022, 09:06 AM
Dry new filter: i shake it for rattles, then finger wipe the center hole, then decide to fill it.
New Torque Converters can fail the shake rattle test...from weld balls.
  #47
Old 10-11-2022, 10:29 AM
dataway's Avatar
dataway dataway is offline
I'm guessing it is to conserve materials ... much less metal to produce. Perhaps to help prevent problems with less than high quality spin-on filter casings, seals, threads etc.
  #48
Old 10-11-2022, 11:39 AM
AMEN! AMEN! AMEN! THANK YOU BROTHER FJ
  #49
Old 10-11-2022, 12:26 PM
track73 track73 is offline
Times 2 on post 43.
1979 Trans Am WS-6 .030 455 zero decked
flat pistons
96 heads with SS valves
041 cam with Rhoads lifters 1.65 rockers
RPM rods
800 Cliffs Q Jet on Holley Street Dominator
ST-10 4 speed (3.42 first)
w 2.73 rear gear
__________________________________________________ _______________________________
469th TFS Korat Thailand 1968-69 F-4E Muzzle 2
  #50
Old 10-11-2022, 12:50 PM
nas t eh nas t eh is offline
Originally Posted by Dragncar View Post
You can take care of the by pass by using a K&P filter without by pass. It flows so much the PMD by pass will never open. or, plug the PMD by pass and run a K&P filter with a by pass built it.
Again, the filter flows so much there is little chance of the by pass ever opening but its still there in case of a emergency.
Yes , but K& P filters for Pontiacs are a difficult find up here., so I replaced the filter housing with a plate and hoses to a remote dual housing and run two large Ford filters with internal filtered bypass. Not popular on this board, but my take on the issue,. I like Sirrotica’s solution better, but I set this up 35yrs ago. I may upgrade once the car is on the road again.
73 T/A 455, 4speed
  #51
Old 10-11-2022, 01:07 PM
72projectbird's Avatar
I like Rainmans vids. He's a good mechanic, and pretty damn smart with his diagnostic work. That said, I always prefill my filters. Have engines with 200k+ miles on them, and every change I prefilled the filter. No abnormal engine wear, no bearing material in the filter, no lifter noises, etc.
If you dont wanna prefill it, knock yourself out. I'll continue to do it.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
  #52
Old 10-11-2022, 02:03 PM
242177P's Avatar
242177P 242177P is offline
It's hard for me to take this guy seriously. He replaced bearings (rod knock) in car. That doesn't sound like something a two-micron-is-death guy would EVER do. And pointing at what the industrial sector does for justification?
I say Unleaded fuel is evil, because airports have Low Lead.
Two stroke road bikes should come back, because logging.
  #53
Old 10-11-2022, 02:07 PM
Sirrotica's Avatar
When you say no one is interested, you can't see how many people contact me via PMs to ask about the filters. You'd be surprised who already owns them, and they're asking me about parts and supplies, but for whatever reason won't subject themselves to all the critiquing on the board.
Let me say there are some prominent, respected people on this board that own, and use by pass filters, so the assessment that no one is interested is not at all true. I do see resistance by the same people that are set in their ways, and will never change, funny thing is, I used to be that guy that didn't think I could improve on what Detroit gave us, or didn't care to invest in one.
The discussion always comes back to aesthetics on old cars, so if you don't have one and don't want one, that's fine. Thing is, I drive Pontiacs 100% of the time, they are my daily drivers 100% of the time, I don't drive a Honda, chevy Buick, etc. car, nor would I own one. For daily drivers it does make sense to use a by pass filter so I'm really not addressing the hobby cars for the most part. Although my hobby car will have one, clean oil is never a bad thing.
I have noticed some of the performance shows on TV paying a bit of attention to by pass filters in the last 5 years or so, so I don't think everyone that owns a performance car won't use one because of aesthetics.
When I see some pictures of engines that have failed shortly after a build, and see bearings torn up for no apparent reason, you know that there was something run through them. Could those engines been saved, maybe, maybe not, each circumstance is different. It sure wouldn't hurt though to have another line of defense that makes a full flow filter look about as efficient as a piece of window screen. Did someone put a filter on that had foreign material in it, did they contaminate it unknowingly?
Mike G has posted as I have, that just because you have a new container of oil, doesn't mean that it isn't contaminated, and is pure and clean. Quaker State had clear containers for a short period of time, and then did away with them. It's a possibility someone looked at something in the container that wasn't supposed to be in there. I've seen some questionable stuff at the bottom of oil bottles in the last 55 years. Remember where crude oil comes from, it's buried in the ground, and sometimes the ground gets into the finished product, along with corrosion, and sediment in the processing equipment.
Flame on.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #54
Old 10-11-2022, 04:35 PM
grandam1979 grandam1979 is online now
Now I’m scared to pour oil in the valve cover much less the filter I’m going to start using a paint funnel before I pour it in. ��
  #55
Old 10-11-2022, 04:39 PM
It probably needs to go through a by-pass filter before it hits that funnel
  #56
Old 10-11-2022, 04:47 PM
Verdoro 68's Avatar
What if the funnel is dirty?! I'm just going to stop putting oil in my engine to keep it clean.
Ken
'74 Ventura 350
'69 AMC Javelin SST
  #57
Old 10-11-2022, 04:49 PM
LOL you guys are killin me
  #58
Old 10-11-2022, 04:50 PM
Dragncar Dragncar is offline
Yes but they recommended using a Lee filter with a internal by pass that is not even available anymore.
I am not even sure if we have available paper filters with a built in by pass these days. Maybe we do but I am no fan of blocking the PMD by pass.
Dirty oil is better than no oil.
  #59
Old 10-11-2022, 05:00 PM
Wix filters state they have a bypass valve. Some filter companies just call it a differential pressure relief valve. It's there in case the filter gets clogged.
So I did a quick search to see if others pop up and surprisingly enough it's stated in several articles that most of your paper spin on filters now incorporate a bypass valve. I know the Wix does because I cut those open on a semi regular basis. I haven't cut open any other brand in a long time so can't say for sure.
  #60
Old 10-11-2022, 05:49 PM
Yep. My wife’s Camaro has a canister type oil filter.
Dr. Thomas Sowell
Closed Thread
