Optional 65 GTO hazard flasher
Was the optional hazard flasher for 65 GTO a factory installed, or a dealer only installed Option? Any help appreciated. Thank you.
Everyone I have seen has been a ADD-ON parts piece.
The Flare-Stat is one of the dealer installed optional units. They pop up every now and then. They come with a plug in harness that fits right into the factory wiring harness.
It was Factory or Dealer installed.
There are two types of kits; An early 1965 kit that required a hole to be drilled in the lower DS dash, this was due to the early Speed-O gauges not having the hole punched for the bulb socket. The 2nd/later kit had the correct socket to plug into the back of the Speed-O pod. If you happen upon an early kit but have a late build '65 Lectric Limited has the correct harness for the Speedo
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
Thanks for the correction Jeff. I was speaking from my experience on my ‘64.
Bought a 4 way flasher kit for my 64 Lemans, was a universal kit made by Flare stat I do believe, 5 wires to hook up from what I can remember.
But upon using the flasher and stepping on brake pedal, the engine started to crank. Was feeding power back to ignition switch thru brake pedal switch. Maybe I had some wires crossed?? No they were all the same colour, LOL. End up putting diode in the brake switch wire so it could not feed power back into the pedal. Kinda scared me first. works good now though. Just haven't had a need to use it yet.
64 Lemans hardtop 4spd, buckets |
Disregard my post
Guys,
I really went far left and just realized the OP was asking about Flashers and I brain-farted into Parking Brake. My apologies. However, the Hazzard Flasher kit was also a Factory or Dealer add-on. Cheers.
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
FWIW here is the same thing installed in my 65 Chevelle. I think Pontiac used a little chrome bezel and mounted it horizontally under the dash, but this is how they put them in Chevelles. The switch and wiring are all the same as Pontiac though.
https://www.youtube.com/watch?v=ZbOWf33oT7k I *think* this one shows more how Pontiac installed these. This was in my 65 Chevelle wagon. The bezels actually used may have looked different for Pontiac. But like I said above, the wiring and switch are all the same. In this instance I used a reproduction switch and had to rewire it a bit to fit the A-body system, but that was just get the wiring into that little half moon plug connector. I used my original referenced above as a guide along with a wiring schematic I found in a dealership accessories install manual. https://www.youtube.com/watch?v=hqQenB2mceU
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO Last edited by Rich-Tripower; 10-19-2022 at 08:52 AM. |
Thank you all for your responses. It was on the car when I purchased it. When I got the PHS documents I also ordered a reproduction window sticker. The flasher was not listed on the sticker. It is a Flare-Stat plug & play unit so I'm assuming it was dealer installed or a previous owner installed it. Thank you all again.
Yep, dealer installed. On the original dealer invoice for my Chevelle the flashers are listed, but as a dealer install for sure. Again, FWIW:
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO |
So cool, wish I could get posi-traction installed for $37.70 nowadays!
And one of those accessory hazard flashers for $8.95!
The Following User Says Thank You to Rich-Tripower For This Useful Post: | ||
The YouTube video looks just like the under dash flasher unit on my old 66 lemans. Also not on the phs
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
'65 FLARE-STAT's had a full Chrome mounting bracket and I've seen at least two styles of knobs.
I don't know if it was just an early or late thing, what I didn't like about some of the early switches were the clip-on/pinch connectors Vs the plug-and-play in '66, The '66 mounting bracket differed slightly see attached;
