Old 10-22-2022, 01:02 PM
charlie66's Avatar
Its and open scoop. No problems there
My Half AN Injun.....
  #42
Old 10-22-2022, 01:03 PM
charlie66's Avatar
As for the bog , would it matter having a 1:1 linkage ratio?
  #43
Old 10-22-2022, 01:08 PM
Scott65's Avatar
Scott65 Scott65 is offline
The dominators I've used (on gasoline) have had excellent response with the 1:1 set up. I think the booster design is responsible for the very good response, but I'm no expert.
'65 Tempest 467 3650# [email protected]
  #44
Old 10-22-2022, 01:20 PM
charlie66's Avatar
just did the 1 minute test and it pumped 1 3/4 gallons .
  #45
Old 10-22-2022, 01:24 PM
charlie66's Avatar
Yeah with the 91 octane i could stump it and no bog at all .. Maybe ill play with the throttle blade positions..
  #46
Old 10-22-2022, 06:18 PM
Mike S's Avatar
Mike S Mike S is offline
I have no experience with e85. I was having a problem getting it rich enough on gas. What I found was my rear screw in jet extensions in the back only had a hole equal to a 90 jet. Ended up drilling the hole in the extension bigger.
  #47
Old 10-23-2022, 07:24 AM
charlie66's Avatar
I drilled mine also. I even put .015 in for hi speeds .
What size nozzles do you have for your pump shot?
  #48
Old 10-23-2022, 02:38 PM
Dragracertoo Dragracertoo is offline
Is this Dominator still 100% gas built?
  #49
Old 10-23-2022, 03:42 PM
charlie66's Avatar
No it is converted for E85
  #50
Old 10-23-2022, 04:07 PM
Who converted it?
What do they recommend?
I had to have 'Max Jets' for mine I believe.
(Do they still make those?)
  #51
Old 10-23-2022, 04:17 PM
charlie66's Avatar
Who converted it?
I did..
Ive done a few 4150's with no issues. Im guessing the 4500 is a different animal. I believe its because the 2" blades . Its alot of air being introduced when opened up fast. Thats just my unfolding opinion for now . I'll keep at it an see what happens .. I will say that i had a hard time getting the bog out on 91 . So maybe im wasting time ...
  #52
Old 10-23-2022, 08:48 PM
My 1150 Specs
booster .500 annular
PV 4.5 4 window, ( I plugged, jetted square)
PV channel Restricter .104
Accel Pumps 50
Pump squirters .055
Main Jet 94/107 ( I am 110 square )
HS bleed .025
IFR .052
Transition slot rest .078
LS bleed .059Fuel 6.5 psi
Hope this helps
  #53
Old 10-24-2022, 07:45 AM
grandville455's Avatar
If these are your gas blocks, and u didn't increase the main well size then that's a big part of the problem, what did you do for booster hole sizes, booster feed sizes etc! if that is all for gas yet u are gonna chase your tail forever!
Darby
M/T 275/60 ET SS Drag Radial
  #54
Old 10-24-2022, 08:07 AM
charlie66's Avatar
My 1150 Specs
Accel Pumps 50
Pump squirters .055
HS bleed .025
IFR .052
Hope this helps
It definitely helps.
Are you set up for E85 or gas? Does yours bog when you floor it or are you good with that?
What does the .500 mean for your booster? Mine measure .182 for the pin hole inside of the booster. Whats yours measure ?
My PV is a 6.5, 4 window . I needed the fuel to come in earlier .Back is plugged as well.
My PVCR's are .076
My pumpshots are .045 front and .055 back. Im going to try .060 in the back. If i give it a quick half throttle it dosen't bog so im thinking that the bog has more to do with the rear then the front squirter.
My front jets are .090 rear .110
My HS in front is .018 back .013
My IFR is .050
When you say transition slot at rest, do you mean its exposed .078 (showing at closed) ?
My IAB's .056
Just throwing my setting out there . Maybe you will see something i did wrong . As you can see, I have it set up to go rich. Its just not listening . Lol!
Thank you for sharing your settings its good to see what others are doing. The only difference is the 100 more cfm's. Not sure about the needed difference in general but its still a comparison .
  #55
Old 10-24-2022, 08:17 AM
charlie66's Avatar
They are gas blocks. The angle channels are drilled to .190 and the main wells are drilled to .205
Boosters are ..182 .
Im definitely chasing my tail for sure . lol
  #56
Old 10-24-2022, 08:27 AM
Mr Anonymous's Avatar
"So i converted over to e85"
Did you "convert" your current carb to E-85, pay someone to do it, or change carburetors?
A metering block change is a necessity.
Clutch Guys Matter
53 Studebaker, 400 pontiac
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
  #57
Old 10-24-2022, 08:39 AM
what size and how many emulsions? What about the hole size in your actual boosters?
Darby
  #58
Old 10-24-2022, 08:40 AM
73 TRANSAM 73 TRANSAM is offline
I would go at least 55 on the squirters.
  #59
Old 10-24-2022, 09:40 AM
charlie66's Avatar
I myself converted it
  #60
Old 10-24-2022, 09:42 AM
charlie66's Avatar
2 emulsions for each main well .028 .
.182 for the booster hole
