Old 08-16-2006, 08:44 PM
lucerne blue lucerne blue is offline
Default i feel 'em coming on.
Thanks. I think I feel those cramps already!! Hope the wife stocked up. Bill
Old 11-20-2022, 12:00 AM
Jon Salem's Avatar
Jon Salem Jon Salem is offline
Originally Posted by george kujanski View Post
The earleir designs were really simple and just needed a coil (-) connection and ground. Later tachs needed a power source AND the coil signal.
george
I currently have a clock in my '71 lemans dash and want to replace it with a one wire tach from a '70. The car still has points. Sounds like I just connect the single brown wire to the neg coil terminal and ground thru the mounts. Should I have any other concerns? Was a special coil used? Thanks.
PontiRocket
Old 11-20-2022, 12:01 AM
Jon Salem's Avatar
PontiRocket
Jon Salem's Avatar
I currently have a clock in my '71 lemans dash and want to replace it with a one wire tach from a '70. The car still has points. Sound like I just connect the single brown wire to the neg coil terminal and ground thru the mounts. Should I have any other concerns? Was a special coil used?
PontiRocket
Old 11-20-2022, 10:43 AM
george kujanski's Avatar
Yep, that should work.
George
