Old 11-21-2022, 09:07 AM
Gary H's Avatar
Gary H Gary H is offline
Default Throttle body size recommendation
I'm building an engine for a customer and the boost arena is something new for me. I'm looking for some recommendations on throttle body size for this combination.
The engine will be a 525" aluminum block, 4.5" stroke, KRE High Port 380 CFM heads, hydraulic roller 255/265 duration, Northwind intake with fuel injection rails added by Wilson manifolds, gooseneck forward to throttle body, 9.25 compression, dual TorqueStorm procharger belt system with two intercoolers
This is a street / show car 79' Trans Am, 6L80E transmission, 3:73 gear 9" rear. I have had recommendations from 90 - 105 MM on the throttle body and I simply don't know. Any thoughts are appreciated
Old 11-21-2022, 09:28 AM
johnta1 johnta1 is online now
What RPM range and how much boost?
Try this calculator:
Induction CFM
Old 11-21-2022, 02:54 PM
Gary H's Avatar
Hey John, since it's a street car probably see 7000 max. Regarding boost, probably on the 12 lbs range
Old 11-21-2022, 03:58 PM
I'd say it would need around 1900/2000 cfm throttle body. (more for racing, but 'street' use probably good enough)
My 'Toilet Bowl' is 4" diameter (around 101mm I think) which supposedly flows 1500 cfm. You would probably need the 105mm at least?
Probably good for street type use. But I'd try for a little bigger?
Found this on sizes on Killer Ron's website:
The biggest throttle body features a purple*throttle blade*and comes in at 1800 CFM (4.100" Butterfly). This unit is set aside for the bigger cubic inch/higher horsepower applications. Engines from 421" to 572"*can put this throttle body to work.*
105mm would be smallest I'd go.
Link to the 'Terminator' style throttle body of Flying Toilet:
Terminator
May give some ideas on the size.
Old 11-21-2022, 05:22 PM
105 mm is a very common size for the Accufab and Holley throttle bodies (single blade).
The LS Intakes in this intake system can mount a 105 mm Throttle Body as designed right from Holley for LS Chevy engines,
see photo.
I personally would not use anything smaller than the 105mm TB. So you have a choice on either a 4 BBL 105 MM TB flow
or a single 105 mm TB flow set-up.
Name:	LS UPPER Throttle Body mounting..jpg
Old 12-04-2022, 05:01 PM
ErikW's Avatar
ErikW ErikW is offline
We run a 105mm on our 461 cu.in. twin turbo car. seems to like it.
ID:	603031   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 12-04-2022, 06:13 PM
charlie66's Avatar
105 or bigger
My Half AN Injun.....
