Old 12-20-2022, 11:08 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Default Port volumes
Never seen a master list of port volumes for the Pontiac iron heads. Is that info out there? I suppose Nhra may have that info in some form?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
Old 12-20-2022, 11:15 PM
JSuchma JSuchma is offline
IIRC, Pete did some articles in HPP years ago listing the factory cast iron heads, with port flow and volume.
The Following User Says Thank You to JSuchma For This Useful Post:
Old 12-21-2022, 07:58 AM
25stevem's Avatar
25stevem 25stevem is offline
1967 to 74 D port heads where 154 CCs.
1975 to 1977 D ports where on average much closer to 155 and some times a tad over.
These would be the 5 series and 6 series heads.
The 1969 722 RA4 heads and the 1970 614 casting RA4 heads where some 184 CCs.
The 1971 and 1972 455HO heads where 172 CCs
1973/1974 SD 455 heads where 186 CCs or a tad more depending on the core shift they may have.
NHRA list the maximum that they allow within there rules, which is always greater then stock.
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 12-21-2022, 09:40 AM
J.C.you's Avatar
One reason I asked is obviously the deeper chambers heads would have less port volumes than the shallow castings.
Also the 6x series had a more rectangular short turn area than the earlier castings.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-21-2022, 09:42 AM
Vizard has been cranking out interesting videos lately. 1 video shows how he makes biggest power with greatly-reduced Port volume: epoxy-fill the floor about 1/4" to 3/8" thick.
Pro-ceiling flow, widen the ceiling if ya can, against floor flow due to dominant flow along the Bowl+CYL backwall. Floor flow only causing misery.
I forget if sbc or BBC, but fairly irrelevant, and goes to show either JB-Weld or another epoxy, and how to drill the runner floor and side to lock the plastic in. I was impressed.
Shows dyno results compared to the known highest hp head and beats it at low and high rpm by a wee bit, and a sag in mid-range by a wee bit. Overall insightful.
I'm not about to do that to Ram Air IIs, but the 48s ( or find a set of 13s for example) would generate a good dataset.
Old 12-21-2022, 01:11 PM
Stan Weiss's Avatar
Yes NHRA does have a list of max port volumes. I had it at one time but cannot find it now, But almost all production heads when measured will be smaller than those numbers.
Stan
Pontiac Pump Gas List
Old 12-21-2022, 01:14 PM
Stan Weiss's Avatar
Mark,
It was a BBC. But this has also been done in Ford Cleveland heads for many many years.
This is a Super Stock Hemi head. The rules say you can port them, but they still have to have the same port volume. In this case they brazed up the bottom of the port.
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 12-21-2022, 01:38 PM
J.C.you's Avatar
Mark,
Stan
I believe Lynn McCarty SS combo the floors are epoxied…..so common to raise ports and lessen the short turn as much as possible.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-21-2022, 02:23 PM
Vizard was definite and clear to say reduced volume, CSA to make the same broad TQ, and HP than an excellent BBC head.
A new life for 301 heads! Reduced CSA for the Win !
Old 12-21-2022, 04:15 PM
Stan Weiss's Avatar
Mark,
It is about best use of CSA. This shows where DV removed metal from. This is why David always talks about "Port Energy".
Stan
Old 12-21-2022, 05:34 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Smallest port with the highest CFM wins if the port is large enough to feed the engine. If the engine is port restricted the larger port with the most CFM usually wins.
Go fast, see Elvis!
Old 12-21-2022, 06:06 PM
J.C.you's Avatar
Meaux has that information in his program
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
Old 12-21-2022, 06:32 PM
PAUL K's Avatar
I have it in my head.... Meaux's system is probably better as long as the lights stay on and there isn't a power surge.
Go fast, see Elvis!
Old 12-22-2022, 09:44 AM
I thought Meaux was only in the exhaust config-calc biz. Will look up the Inhale stuff.
Old 12-22-2022, 09:57 AM
bankbook's Avatar
bankbook bankbook is offline
I have a set of Bob Micheals SS 6x heads from 1992 that have a lot of port/floor work including epoxy that verify's the turn comment. Work done by Heads Up in Ohio.
Will be flowing them soon. Really nice work.
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 12-22-2022, 10:08 AM
slowbird's Avatar
slowbird slowbird is offline
Any pictures?
Old 12-22-2022, 02:34 PM
J.C.you's Avatar
Off topic but….
If someone didn’t have anything else to do, I believe one could graft two iron heads together, raise the ports and make a killer iron cheater head.
Borrowed this pic SS sd head
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
The Following User Says Thank You to J.C.you For This Useful Post:
Old 12-22-2022, 03:03 PM
25stevem's Avatar
It has been done by at least one AMC racer as I recall, but a holy crap it must be a ton of work to but it mildly, and likely took many attempts!
If I recall right a fellow named Hemmy Adkin running super stock back in 99 was running 9.50s with a non stacked and welded, but heavily port heads and making according to him 718 Hp from 277 cfm of intake flow and 257 out the exh both at .700”.
Old 12-22-2022, 10:18 PM
@ Stan; the Induction Optimization Program IOP seems interesting.
Old 12-23-2022, 11:38 AM
68azbird 68azbird is offline
So how much power did these heads make on a 406 cubic inch pontiac?
Intake flow
@28 h2o
.100 = 75
.200 = 144
.300 = 189
.400 = 205
.500 = 209
.600 = 209
Exhaust flow
.100 = 53
.200 = 107
.300 = 147
.400 = 169
.500 = 167
.600 = 182
162 cc intake port volume
It is easier to fool a man than it is to convince he has been fooled
