#161
It’s funny watching grown men argue over something neither own lol!! We would need valid results from prior runs with car and weather compared to the new setup with same conditions etc. so many variables when not done on the same day or even same track if it wasn’t?
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
The Following 2 Users Say Thank You to grandville455 For This Useful Post: | ||
#162
Rob,
Thanks. How close is this to your time slip? 60 Foot ET = 1.3445 330 Foot ET = 4.0191 1/8 Mile ET = 6.3541 1/8 Mile MPH = 104.9772 1000 Foot ET = 8.3828 1/4 Mile ET = 10.1123 1/4 Mile MPH = 130.1399 Stan
#163
What does the whole time slip say ? Cars weight too if you could.
#164
![]() Quote:
combo. Take a look at this pump gas stroker who won their class in 2016. Notice the cam, a little 261-269 deal. Made enough HP to get Mikes car down to 6.36 at 107 MPH for 3750 lbs. His 505 should have been able to make more power than that. Biggest problem I can see is that cam. |
#165
![]() Quote:
… and a wrong cam choice shouldn’t make the car faster, that doesn’t make sense … … also worth noting is the launch and shift RPM is the same … … I’m sure Mike is looking forward to figuring out what the new heads will like as far as any tuning changes 👍🏻… |
#166
![]() Quote:
Just help Mike get his 60' foots down. Gotta have it. No self respecting 505 with a 8" converter and 4.10s should have a 1.44. |
#167
![]() Quote:
#168
You can make all of the engine, and convertor changes you want. But in the end it still comes down to what is the max forward thrust the suspension and tires will let you use. If you are data logging look at G's.
Stan
#169
As the Pontiac world turns, so are the days of our lives.
The Following User Says Thank You to Little Jack For This Useful Post: | ||
#170
Well, well, look at that. CV-1 talk is good.
Langer posted,now Little Jack posts from a new account. Its good for the forum. |
#171
![]() Quote:
Maybe a kid of LiL Jack's ??? ![]()
#172
John,
Or could be after not posting for a while he forgot his password and so needed to create a new account. Stan
#173
![]() Quote:
Jeff Kinsler’s is the same way. |
#174
![]() Quote:
Were you able to get out and race any this year? If so how did you do? It seems ever date on the Warriors schedule this past year I had something else I had to do. Stan
#175
![]() Quote:
Send a PM to eric_cspan the forums admin and he’ll get you back on using your previous account. |
#176
![]() Quote:
We ran some mid 4.50s in the eighth. Broke the converter at one race and had an automatic shifter issue at the last race. It’s out for a check over at this time. Definitely needs rings but head gaskets looked great. |
#177
![]() Quote:
Sounds like you had a pretty good year. Are you just going to freshen the engine or do you plan on any upgrades? Stan
#178
… launch rpm and shift rpm are the same from what Mike has told me …
#179
That sentence was totally something he would say. His sense of humor, he made all kinds of posts like that in the past.
Its good to hear from him, been wondering what he was up to. |
#180
![]() Quote:
Just new rings and bearings. |
