Old 02-23-2023, 04:54 PM
SD455DJ SD455DJ is offline
The hood is sans its primer coat and the original Palladium Silver paint beneath. Once the weather turns a little nicer and the roads clear up the Custom S will take a short journey down the road to the paint booth.
Dennis
ID:	607736   Click image for larger version
Old 02-25-2023, 01:13 PM
A couple of the doors had this tag under the door card...BAL is for Baltimore I assume, 49 for the week? It has an 11D build date on the trim tag (47th week of the year +/-), so probably means something else? Here are the stamps found on the hood (1B20?) and pass rear qtr. trunk opening (23369 X4G?).
Dennis
ID:	607880   Click image for larger version
Name:	Hood Stamp Drvr Frt Side.jpg
ID:	607881   Click image for larger version
Name:	Rear Qtr. Stamp.jpg
Old 03-17-2023, 07:50 PM
Default Update
The Custom S has been getting prepped this past week for painting sometime next week. The windshield and rear window were removed and minor rust was found at the windshield base that needed some metal work. Fortunately, the rear window channel needed only a little tweaking otherwise was in great shape. The rear window’s seal had a breach at the bottom channel and would let water in the trunk, but, fortunately the car led a garaged life, so no damage (rust) in the trunk. The entire interior is now out, save for the dash and steering wheel, so this is getting pretty serious for a ‘scuff and shoot’! The front fenders were removed and the back sides and inner fender wells were covered with something like ‘cosmoline’ that is practically impossible to remove, so more work needs to be done to get them ready. The original carpet (tags are still on the underside) got a first cleaning along with the original seatbelts. The front bench seat base is pretty ripped and worn (hence the seat cover) and we’re going to take it to the upholsterers to see if they can match the vinyl grain and pleat pattern. The seat back looks to be in nice condition.
Dennis
ID:	609016   Click image for larger version
ID:	609017   Click image for larger version
ID:	609018   Click image for larger version
ID:	609019   Click image for larger version
Old 03-17-2023, 08:04 PM
Thumbs up
First rate preservation/restoration as expected.
Old 03-18-2023, 12:46 PM
Thanks B-man! I don't know about first rate restoration, maybe a rejuvenation, but, whatever you want to call it, it will be a dependable fun driver when done. It's getting more attention than I thought it would receive in such a short time, but it will be ready for the nice weather this May.
We did discover the engine 'lean' to the driver side is due to collapsed factory motor mounts, the driver side being particularly bad, so new ones from Ames are on the list of parts to be ordered next week. We also have new DGA10S 2.5" mandrel bent downpipes also on order that will tie into the 2.25" exhaust system it has now (fairly new...10-12 years old and still shiny in places) along with new MagnaFlow (straight-thru design) mufflers to replace the Midas corks that are on there now.
Dennis
Old 03-18-2023, 02:49 PM
The original carpet is in decent shape, just a little worn and sun faded, so going to do the 'redye' restoration. The jute back is in great shape too. This is the rear carpet and the tag fell off from somewhere...
The front carpet has a Nov. 1, 1968 date, while the rear has Oct. 31, 1968.
Dennis
ID:	609060   Click image for larger version
ID:	609061   Click image for larger version
ID:	609059   Click image for larger version
Old 03-18-2023, 03:02 PM
Here's the inner fenders with the brown-ish looking coating (cosmoline?) on the top and the results of a few hours of scrubbing with mineral spirits (did nothing), paint thinner (did nothing), then gasoline (did something). He even sprayed the cowls as seen in the May '82 picture. It took quite a bit of rubbing with gasoline to clean it off the cowls.
Dennis
ID:	609064   Click image for larger version
ID:	609065   Click image for larger version
Name:	May '82 Custom S Body Work.jpg
ID:	609066   Click image for larger version
ID:	609067   Click image for larger version
Old 03-23-2023, 07:13 PM
Fresh Palladium Silver paint applied this past week. The top of the dash and cowl and rear package shelf are getting painted tomorrow. It gets kicked out of the shop on Monday for reassembly. It's finally one color now!
Dennis
ID:	609526   Click image for larger version
ID:	609527   Click image for larger version
ID:	609528   Click image for larger version
ID:	609529   Click image for larger version
The Following 2 Users Say Thank You to SD455DJ For This Useful Post:
Old 03-17-2023, 08:24 PM
I had to do the bottom of the front seat on my LeMans wagon (the wagon version of the LeMans uses a Custom S interior). I bought some NOS material from the guys in Oregon which was a perfect match but we had to sew the pleats which were heat pleated originally.
Old 03-18-2023, 12:26 PM
North, that's the bug-a-boo, you can't replicate the factory heat-set pleats at a local upholstery shop, so the sewn pleats will have to do. I have to remember that this is a driver quality 4-door sedan, not a RAIV Judge, so close enough is good enough. We'll see what vinyl's he can get to try to match the factory grain, so hopefully we can get a reasonable match.
Dennis
Old 04-16-2023, 08:18 AM
KSZR KSZR is offline
That dash tach is not the easiest to install from my experience.
Old 04-22-2023, 07:32 AM
GTO.PAUL GTO.PAUL is offline
Default '69 Carpet
Any chance you have some front and back carpet pics of the bottom side before install. Mainly want to see the seat track locations. Looking great! Thanks, Paul
Old 04-22-2023, 11:02 AM
Paul, Here are the only shots I took of the backsides before reinstalling them.
Dennis
ID:	611199   Click image for larger version
ID:	611200   Click image for larger version
ID:	611201   Click image for larger version
Old 03-24-2023, 02:03 AM
Verdoro 68's Avatar
Wow, you guys move fast!
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 03-24-2023, 08:31 PM
This situation is the opposite of body-shop jail...we only have a 2-week window to get the car in and out of the shop before the next cars need to move in, so it was a take it or leave it deal, and these opportunities come along once every blue moon. So, we pulled the trigger and accepted the challenge to squeeze the Custom S in, pitch in a bunch of labor and help out as much as possible to keep the progress moving. It's moving out next Monday or Tuesday, so 2-weeks to the day it moved it, so we have to move fast! It sure has been crazy, but it's been rewarding to see it change for the better...so quickly. And, of course, we are doing more than we originally planned.
Dennis
ID:	609611   Click image for larger version
ID:	609612   Click image for larger version
ID:	609613   Click image for larger version
Old 03-24-2023, 02:58 AM
Now you’re just showing off.
Old 03-24-2023, 08:35 PM
It's what I do best...lol.
Dennis
Old 03-24-2023, 08:53 PM
We never noticed this before, but the underdash Kraco 8-Track player has integral speakers built-in to the sides of the body case. We've never seen this before, but I imagine this was one of their offerings if your car didn't have speakers.
Dennis
ID:	609620   Click image for larger version
Old 03-26-2023, 11:30 AM
Solved the mystery on the internet...Kraco KIS-444 "Instant 8-Track Stereo With Built-In Speakers"...
Dennis
Name:	Kraco w-speakers box side.JPG
ID:	609730   Click image for larger version
Old 03-26-2023, 01:44 PM
My 69 Executive had a similar (but not identical) 8 track player when I bought it. Interestingly the original owner was evidently worried about doing any damage because he mounted that player on the floor but instead of screwing it to the floor he screwed it into one of those tissue-trash bins with the weighted flaps that sat on the hump. He also wired it directly to the fuse block to not cut the factory wiring to the radio.
I couldn’t stand looking at it but wanted to preserve at least his intent to have recorded music by replaced it with a factory floor mount player.
