Old 12-12-2022, 09:10 PM
RA1John RA1John is offline
Default Rally II Wheel Color/Finish (rear)
Trying to determine the factory correct color/finish used on the rear of Rally II wheels. At least for '67-'69, examples I've found appear to be a grey with green, black tint. Semi gloss finish.
Definitely not plain light grey.
Appreciate any paint type, formula to achieve this.
Thanks!
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
Old 12-13-2022, 07:20 AM
J GLASGO's Avatar
J GLASGO J GLASGO is offline
Rust oleum light machine grey is dead on.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of!
Old 01-03-2023, 09:00 AM
1stgenbird's Avatar
1stgenbird 1stgenbird is offline
That's what I use when refinishing Rally II wheels.
Old 01-09-2023, 08:57 PM
So many color variations in R2's, even within the same model year.
Old 01-09-2023, 10:37 PM
Thanks!
Looks like you have a pretty clean sample wheel. Just take the wheel to an automotive paint store that has a photometric eye, and they should be able to mix something for you that matches it.
Old 01-13-2023, 04:54 PM
It’s odd no overspray by the holes ?
Old 01-13-2023, 05:33 PM
Took a Picture of the one I use I got it way back at a swap meet to use for reference. It’s a grayish green color with the over spray at the openings. But as already said I’m sure it was done differently with different paint shops.
ID:	605107   Click image for larger version
Old 05-07-2023, 12:10 PM
Cammer-6 Cammer-6 is offline
DP-40 works pretty good
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 05-08-2023, 07:34 AM
FunctionalShaker FunctionalShaker is offline
To get the correct greenish grey, it's best to have a paint store custom match it, as nothing on the market does.
Sent from my SM-A125U using Tapatalk
Old 05-14-2023, 09:46 AM
Jimbobeast Jimbobeast is offline
I just got finished spraying my five JL code 14 x x6 Rally II's with Rustoleum Light Machine Gray. 2 cans did all five inner and back.
After I spray the Argent Silver on the front, how long should I wait before masking for the Gray? And, after spraying the gray, how long before removing the masking?
Old 05-14-2023, 09:57 AM
Sorry, here are the pics:
ID:	612626   Click image for larger version
ID:	612627   Click image for larger version
Old 05-14-2023, 10:49 AM
Trevor78 Trevor78 is offline
Must be dead on for another sample, obviously not the green-grey shown and mentioned.
