Old 01-11-2023, 05:26 PM
SD455DJ SD455DJ is offline
Dan's rebuilding a 7029268 Q-jet for the 350HO, the picture is a teaser with another Q-jet to make sure the fuel line (old original from a past rebuild) fits. Dan found an old original thermo-vacuum switch with the plug and hoses (5 fittings) to add to the intake as well as the proper pcv nipple and coolant temp sensor for the idiot light. He needs to rebuild the carb yet, so could be running by Friday! We also see through the fuel pump opening in the timing chain cover that the cam gear is a steel replacement, so scratch that off the list.
Dennis
Name:	'69 CustomS Q-jet.jpg
  #42
Old 01-11-2023, 05:32 PM
Does anyone know if this is an original factory tire (now the spare)? It's an 8.25-14 Uniroyal Laredo 4-ply rated (WW)? '69 appears to have utilized both tire sizing methods, numeric (like above) and the letter series (G78-14).
Dennis
Name:	'69 CustomS Uniroyal Laredo 8.25-14.jpg
ID:	604936   Click image for larger version
  #43
Old 01-11-2023, 06:58 PM
Looks just like the original spare on my 69 LeMans 4dr. A V8 A body (non GTO) would come with 8.25 Blackwall tire and the whitewall version was a super popular option. You could optionally order the G78 and G70 tires that were offered on the GTO but very few buyers did.
Typically the numeric (7.75, 8.25, 8.55 etc) were bias ply while the letter series (E, F, G, H etc) were bias belted and gave you more tread width compared to a numeric tire of the same overall width.
The standard Tempest, Custom S and LeMans tires were the 7.75 black (a wagon, or a V8 or AC or any combination bumped you to the 8.25). These were black or a 3/4” or so white wall. Next up were the G78 in 3/8 red or white line (black wall wasn’t offered) in nylon or extra cost fiberglass. Top of the line were the G70 wide-o-oval in 3/8” white or redline (again no blackwall) in fiberglass only. Those tires were in the $100 plus cost so nobody ordered them.
By the way do you have the correct air cleaner for the 350 HO? It is unique to that engine but can be assembled from other air cleaners. It is the single large snorkel air cleaner base used on the 68 GTO, 68-9 Fbird 400, 69 GP with either 428 and all the 69-69 full sized 428’s except the 360 horse 69 Bonneville 428. The difference is that it uses the black lid from the regular small snorkel 4bbl air cleaner (as used on 68-69 full sized 400-4bbl and the 69 GP with a 400 4bbl). Those lids are physically the same other than the paint versus chrome.
Old 01-11-2023, 07:25 PM
Here is an original one
Old 01-11-2023, 08:59 PM
Thanks North, it's good to confirm that it is an old original Uniroyal OEM tire. I haven't ordered the PHS yet, but option list should show the low-cost whitewall option then, along with power steering, power brakes (drum), TH400 (Power Group?), 350 4-bbl (HO), H.D. Safe-T-Track, the Deluxe Trim Group (deluxe steering wheel, pedal trim, rocker moldings, and full-size wheel covers?), and an AM radio.
No, we don't have another large single snorkel air cleaner, so we'll be looking for one.
Dennis
  #46
Old 01-11-2023, 10:30 PM
The Custom S came standard with the deluxe steering wheel (three spoke). I don’t think yours had the decor group because it would have the wood grain on the dash. The decor group also included window frame moldings, deluxe wheel covers, pedal bright trim and concealed wipers. You could order all that stuff separately though.
The 350 HO cost $188.52 which was only $78 more than the 350 2bbl. But since the HO included duals it really only cost $47 extra. A hell of a bargain to go from 265 to 330 horse! Standard auto trans ratio was 3.23 with or without AC.
Old 01-12-2023, 09:11 AM
Thanks North for the education! I'm learning much about these strange '69 Pontiacs! I've been '70 & later, so this is the oldest poncho I've ever owned...lol! This Custom S has the XH 3.55 Safe-T-Track (upside down in the attached picture) in it that we understand to be the standard rear gear...with & without AC. We did verify the gear ratio too.
Dennis
Name:	'69 CustomS Rear Axle Code.jpg
  #48
Old 01-12-2023, 05:21 PM
Getting a bit closer to looking more 'factree'...should be able to move on its own power tomorrow. Here are before & after pics of the engine change over from 'hotrod' to stock.
Dennis
Name:	350HO Before 1.jpg
ID:	605004   Click image for larger version
Name:	350HO After 1.jpg
ID:	605005   Click image for larger version
Name:	350HO Before 2.jpg
ID:	605006   Click image for larger version
Name:	350HO After 2.jpg
  #49
Old 01-12-2023, 05:53 PM
trishieldchief's Avatar
Very unique cool car Dennis, nice buy.
Rich Johns
www.purestockauto.com
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
  #50
Old 01-12-2023, 06:08 PM
einstein's Avatar
einstein einstein is offline
Nodular rear housing? Look for big "N" cast above pinion nose.
  #51
Old 01-12-2023, 06:16 PM
Thanks Rich! I think I need intervention...
Dennis
  #52
Old 01-12-2023, 06:30 PM
We haven't checked that yet, but it is on our minds to do. We're going to Whistle the engine tomorrow to see what the cold/hot compression ratios are to compare to Dan's '69 350HO Firebird.
Dennis
  #53
Old 01-13-2023, 06:26 PM
I looked up the axle ratio data and some factory documents say 3.23 with auto trans (with and without AC) but most say 3.55 (also with and without AC), given that the ones that said 3.23 were early and/or preproduction. So, either they were all 3.55 or they switched from 3.23 to 3.55 early in the model run. For what it's worth there are some good reasons to doubt the accuracy of these charts because some say there was a 3.08 and 3.36 offered for special order with automatic trans and others say there were no optional ratios. another shows 3.55 as standard with or without AC but also shows a special order 3.55 that can't be ordered with AC ?!?
Regardless this was a stout car. I suspect that without AC and the 3.55 it might have embarrassed many a GTO with AC and 3.23's.
The Following 2 Users Say Thank You to north For This Useful Post:
  #54
Old 01-13-2023, 06:28 PM
One thing I'm curious about is what the weight difference was between a 4 door sedan and say a two door hardtop? the extra 4" of wheelbase must add a 100 pounds or so? Plus the extra two doors?
Old 01-13-2023, 06:35 PM
Dennis
No you do not Dennis ,perfectly sane normal great guy!
Rich Johns
1987 GN Astro Roof
The Following User Says Thank You to trishieldchief For This Useful Post:
  #56
Old 01-13-2023, 07:59 PM
Shiny Shiny is offline
I think you have a very strong support group here.
Very cool to see your recent acquisition that is in such great condition. Thanks for taking the time to post here.
  #57
Old 01-13-2023, 08:08 PM
jamesq's Avatar
jamesq jamesq is offline
From "Pontiac: The Complete History 1926-1979" by Thomas Bonsall - pg 297
1969 Tempest Custom S 4-dr sedan - 3235 lbs
Tempest Custom S 2-dr hdtp - 3220 lbs
LeMans 2-dr htp - 3245 lbs
GTO 2-dr htp - 3503 lbs
FWIW - James Q
James Quayhagen
  #58
Old 01-13-2023, 08:14 PM
JSuchma JSuchma is offline
Just wondering if it might have the Pure Stock Drags in it's future?
  #59
Old 01-13-2023, 08:34 PM
einstein's Avatar
The weights are listed in the AMA charts. Haven't looked at mine in forever, so I don't recall if I have the A-body docs. I'll try to look this weekend.
  #60
Old 01-13-2023, 08:57 PM
OG68 OG68 is online now
I always thought the AMA weights were for the basic car without options. So the GTO would have the V8 and the cast iron Dearborn transmission as well as the upgraded interior and trim.
The custom S would have the OHC and saginaw 3 spd plus basic interior.
I'd say they might be pretty close in weight given the extra two doors .
