Old 01-27-2023, 12:08 PM
PAUL K's Avatar
PAUL K PAUL K is online now
Originally Posted by Dragncar View Post
How many other guys run a 8 second NA Pontiac with D ports ?
You indirectly implied Jim ran 8's in the quarter mile.
I am thinking about a thread or post from not too long ago.
He did do the 320cfm pair of 48s that made 871 HP. Not sure if it had any power adder but you would think it could have.
You backed up your false statement, but implied maybe it was 8's with a power adder. Also blaming your incorrect post on brain fog.
slowbird, I am simply thinking out loud , trying to figure who has done it. It has been done, iron heads in the 8s.
Now you say you never made an incorrect statement, because once somebody does run eights your false statement will become factual.
Might have taken a light car, so what. The Butlers had some guy do it years ago with D ports;
Dan had a guy who could run 8.90s with his RAIVs a long time ago too..
Now your saying other guys (but not the guy you said) ran in the eights, so your false statement should really be considered accurate.... even though it was false.
Jim has been 9.39 with 96s. That a pump gas head.
8s are possible with smaller chamber, more CR and lighten the car up. Or real close to it.
Now you are fantasizing about what someone else should do so you don't have to own the false post you made.
But for some reason you want me to admit I am wrong.
^^^ THIS! Wouldn't it just be easier to own that you were wrong about Jim running eights.... Then you could apply all that waisted time towards getting your Hot Rod running so you don't miss another season of racing.... Just saying.
Go fast, see Elvis!
Old 01-28-2023, 01:02 PM
It's pretty easy to get around 250 at .550 out of iron heads. I have ported many sets. Lower lift numbers are strong and they make good power. I have a set of 48 I did years ago that hit a bit over 270 and that was ten times the work for 10 percent more flow. The port needs to match the combination.
The Following User Says Thank You to chiefbigb For This Useful Post:
Old 01-29-2023, 12:47 AM
Pontiac Derek Pontiac Derek is offline
Jim Robertson or Dan Barton 100%
Build it Right Build it Once!!!
Just another Engine Builder from the Northwest lol
Old 01-29-2023, 04:11 AM
Dragncar Dragncar is online now
You mad bro ?
Old 01-29-2023, 05:00 AM
Fact # 1: The Butlers DID have a guy who could give you a 262-265 cfm head (head after head). With that 265 cfm head the Butlers could run very good times (for that period), BUT THE BUTLERS ALSO RAN HIDDEN NOS ON THEIR ENGINES. So the Rodney/David Butler 265 cfm heads that ran in the 8s ran there because of several reasons. Spray, light weight, good cast iron heads, lots of track time.
Fact #2: The man has since passed on (years ago).
Aluminum Heads from Edelbrock was Jim Butler's solution to not having the cast iron employee's porting skills available.
Old 01-29-2023, 05:07 AM
Few know more than bits and pieces of what really occurred in the early Pontiac/ Butler
Days. I believe Dan Whitmore was another guy with a lot of talent, just like Butler's guy, AND Barney Mahovitz, AND Mr Robertson.
Hope I spelled Barney's last name correctly.
Old 01-29-2023, 10:20 AM
PAUL K's Avatar
You mad bro ?
No Sir. Just trying to keep PY from turning into PZ. Also don't mind giving you tips on time management. That's what this site is for. Pontiac folks helping Pontiac folks.
Hope you get the Hot Rod done. Two missed season's is a percentage of time lost.
Go fast, see Elvis!
Old 01-29-2023, 10:31 AM
PAUL K's Avatar
I remember when Whitmore's top guy was going up against Rodney Butler in a final round. He was suspicious because the Butlers kept pulling their car into the trailer to work on it.... He opened the door to the trailer and found the "hidden" nitrous system.
Round ports run faster than d-ports "for a reason".
Btw... It's Moravits. Barney Moravits
Go fast, see Elvis!
