Old 02-04-2023, 01:42 AM
besserspat besserspat is offline
Default Freezin' balls
Its currently -32 C in Montreal not accounting for windchill thats - 24F for you south of the border. Here, in the St-Lawrence valley its a damp cold that goes to your bones, Im planning a road trip to FL.
My house was built in 1760, no matter the amount of snow around the house acting as insulation, All base boards are cranked up, its still cold inside... and I dont want to look at the meter spinning
My thoughs go to the people and animals out there in the cold...
The Following 2 Users Say Thank You to besserspat For This Useful Post:
Old 02-04-2023, 04:39 AM
dataway's Avatar
dataway dataway is offline
Default Post your temps
3:30 am here .... 19 degrees below zero.
House making some unhappy noises, about a 50 degree temp swing in 24 hours.
Old 02-04-2023, 07:54 AM
Stuart's Avatar
Stuart Stuart is offline
It's a fast moving system, yesterday morning temps were around -20F here but it's predicted to be +30F today.
(by the way, your weather station says PM and not AM. I also have a La Crosse and it's always a pain to get them to display correctly.)
The Following User Says Thank You to Stuart For This Useful Post:
Old 02-04-2023, 08:45 AM
Radman's Avatar
Radman Radman is offline
Noon yesterday 31, 11:30 PM last night 6, 8:00 AM, this morning 8
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 02-04-2023, 08:46 AM
67drake's Avatar
67drake 67drake is offline
The last 3 days it was -22,-17,and -12 driving to work in the morning. Today supposed to be much warmer.
‘55 Catalina
Old 02-04-2023, 09:16 AM
tekheavy's Avatar
tekheavy tekheavy is offline
3 above.
Old 02-04-2023, 09:27 AM
vertigto's Avatar
vertigto vertigto is offline
25 degrees @ 8:27am.
Old 02-04-2023, 10:19 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
-9 in RI, at 515 this morning when the f350 rumbled to life
Old 02-04-2023, 10:29 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
10 degrees @ 7:00 this morning
Old 02-04-2023, 11:12 AM
The Champ's Avatar
Tropical 16 degrees in Madison, WI right now.
Back home, it was below zero first thing in the morning, but the wind was only about 5 MPH so it really wasn't very cold.
At -19, if the wind isn't blowing hard, it's just a chilly day. Not even worth zipping up my lightweight winter jacket.
75ta4spd's Avatar
75ta4spd 75ta4spd is offline
-25 at 7:30 this morning. -15 right now at 10:11 AM in Northern NY.
The Following User Says Thank You to 75ta4spd For This Useful Post:
Old 02-04-2023, 11:41 AM
The Champ's Avatar
shirt sleeve weather.... :}
Old 02-04-2023, 11:51 AM
mrennie's Avatar
mrennie mrennie is offline
Just left Montreal from a 3 day conference. Yeah, bitterly cold. I live 10 hours north and it's actually warmer at home today.
Michael
1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished!
1979 Trans Am - low-buck drag car project for when I retire
Old 02-04-2023, 12:00 PM
1760 ?
Did George Washington sleep there ?
damn that's cold !
+29* F in NC right now , and its a cold day today.
You have my sympathy.
Don't go to Florida right now unless you can Stay There.
You will despise your current arrangements after 2 days in the mid 70's.
Bad medicine
Old 02-04-2023, 12:05 PM
Jonsie Jonsie is offline
63* now
The Following User Says Thank You to Jonsie For This Useful Post:
Old 02-04-2023, 12:10 PM
OG68 OG68 is offline
Low of 49* this morning, 70* predicted high.
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 02-04-2023, 12:47 PM
misterp266's Avatar
5* @ 11:30 this morning. Was about -10* earlier. Lost power last night too. A lot of wind! Luckily it was back on in about an hour and a half. Cold today but back to mid forties to mid fifties next week, I’ll take it!
" Darksiders Rule "
Old 02-04-2023, 12:55 PM
dataway's Avatar
We peaked at neg 20.6 F ....
75TA ... I'm probably with a couple hours of you.
Coldest I've seen here in probably ten years .... coldest ever was around neg 22 ... so very close.
Old 02-04-2023, 12:57 PM
dataway's Avatar
Other than that ... been pretty happy with that thermometer ... the sensor is stuck to a front porch post on the north side of the house and it's trooper, batteries last a year easy and it always seems to work pretty good.
Old 02-04-2023, 01:35 PM
Ab69 Ab69 is offline
Talking
58 at. 10:30 AM ,going up to 78 and will be taking the old tin can for a ride today.
