![]() Quote:
Sorry I really wouldn't know the cost factor. The heads were mildly ported and 1.77 valves when I bought them. That being said I had to go with dished pistons to get to the 9.5 compression. I'm no expert but the cost of porting and dished pistons may be negligible to the cost of aluminum heads. Hope this helps. |
![]() Quote:
Sorry I really wouldn't know the cost factor. The heads were mildly ported and 1.77 valves when I bought them. That being said I had to go with dished pistons to get to the 9.5 compression. I'm no expert but the cost of porting and dished pistons it may pay to go with aluminum heads. Hope this helps. |
![]() Quote:
How about this one?
Butler Comp SP Street Performance Billet Roller Cam (HR) 282/288, 230/236, .510/.521, 112 LS (Std Firing Order/ Std Journals) |
That’s a nice match for your combo in my opinion.
The Following User Says Thank You to b-man For This Useful Post: | ||
I went against the grain with my 455.
8.3:1 compression, runs great on the cheapest 87 octane I can find. Stock pressed-stud heads, with upgraded valve springs, stock rockers/nuts/push rods ("66" castings). Mild low-lift camshaft (.443/.435), and old P4B intake. I do have a very good exhaust system, and also an EFI system that controls fuel and ignition (makes for easy tuning changes, but I doubt makes any more power). 316hp/385tq to the wheels on a DynoJet, on cheap gas. Also runs cool, even in Texas summers. With a stock torque converter and 3.08 gears, it will still smoke 255/60 MT drag radials.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
![]() Quote:
Press in studs and a P4B. I love it when guys run this stuff. Completely respectable dyno numbers too. Lee is my new hero. Viva Le revolution! Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Vid For This Useful Post: | ||
