Old 02-11-2023, 05:55 AM
Kenth's Avatar
Kenth Kenth is offline
Instead of messing with the intake, use the correct flange gasket.
Pontiac flange gaskets for Pontiac Quadrajets, to the left 1970-74, to the right 1975-79.
FWIW
Name:	Pontiac flange gaskets.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 02-11-2023, 12:11 PM
besserspat besserspat is offline
FWIW
If you look at the pictures Ive posted of my HO intake ( first post), then add Dave's CNC program through the intake, then Ill weld a 1/8" divider plate back in.
After that I top it off with a 3/4" thick Nitrous plate which is essentially a spreadbore open space with spray bars.
I will end up making my own gaskets.
Peter
Old 02-11-2023, 04:14 PM
Sooooo, i put a divider in a lightly ported Torker I, couplea decades ago. Drove around, checked a month later and found it sucked into Runner #8.
If ya do any such divider install, go thick on the gauge, and trap it on all edges, real good.
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post:
Old 02-11-2023, 04:51 PM
Its funny I thought of that...what if it flies away? lol I remember when I was epoxying Turtles down at the bottom of single plane plenums on Mopars...
My plan its to cut a groove on the 3 faces using my milling, so the divider gets press fitted in place and then tig weld it in place. If it flies away...Ill buy a lottery ticket.
Peter
The Following User Says Thank You to besserspat For This Useful Post:
